Cylindrical symmetric magnetic field
The problem involves understanding the behavior of a cylindrical symmetric magnetic field and its relationship to Stokes' theorem, specifically how the magnetic field decreases with distance from the axis of the cylinder.
  • Participants discuss the application of Stokes' theorem and the implications of cylindrical symmetry on the magnetic field. Questions arise regarding the constancy of the magnetic field along the integration path and the directionality of current density in relation to the area element.
Participants are actively exploring the implications of cylindrical symmetry on the magnetic field and questioning the assumptions related to the constancy of the field along the path of integration. Some guidance has been offered regarding the relationship between the magnetic field and current density.
There is an ongoing discussion about the assumptions related to the direction of current density and the area element in the context of cylindrical symmetry, which may affect the interpretation of the integral equations involved.
Maike
Suppose the magnetic field line pattern is cylindrical symmetric. Explain with Stokes theorem that the field decreases like 1/r (with r the distance from the axis of the cylinder).
Stokes theorem
I was thinking of a circular loop around the axis. The line integral around this loop is B*2*pi*r. But I don't really know what I can say about the curl of B if you only know about the cylindrical symmetry.
Thanks in advance for helping me out!
Integrating the Maxwell equation for ## \nabla \times B ##: ## \ ##
## \int \nabla \times B \cdot dA=\int \mu_oJ \cdot dA=\mu_o I ##. By Stokes theorem ## \int \nabla \times B \cdot dA=\oint B \cdot dl ##. One question to ask at this point-why is it that ## \oint B \cdot dl =B 2 \pi r ##? i.e. How do we know that ## B ## is constant along the path of the integral?
Thanks very much for your answer!
I think B is constant along the path because of the cylindrical symmetry. Or is that a wrong conclusion?
Are you sure by the way that ∫J⋅da = I in this case? How can you know that J and da point in the same direction? Or doesn't it matter?
Yes, that is correct. ## B_{\phi} ## is constant along the circular path. ## J ## often points along the z-direction in problems with cylindrical symmetry, but it isn't a strict requirement.
  • · Replies 46 ·
