D.E mixing problem with rate out
  • Thread starter Thread starter HappMatt
    Mixing Rate
2 replies · 3K views
HappMatt
A large tank initially hold 40 gallons of water. Pure alcohol enters at a rate of 2 Gal/min is well stirred and the mixture leaves at 1gal/min. What will be the concentration when of alcohol when the tank has 80 gallons of fluid in it.
q= amount of alcohol
i have dq/dt=rate in -rate out
rate in=2gal/min of OH
it will take 40 mins to fill to 80 gal
and the thing I am wandering about is the rate out.
i currently have
rate out=q/(40+2t), but I am thinking maybee its q/(40+t)
as for the rest i think I am fine its just this outflow rate I am not sure on.
Your second guess for the outflow rate appears correct to me, making your differential equation:
[tex]\frac{dq}{dt}=2-\frac{q}{40+t}[/tex]
Any reason you are not sure that you would like to discuss?
Don't forget that when you are answering the problem they are asking for concentration of alcohol; your state variable q is currently defined as the amount of alcohol in gallons.
well at first i was thinking of using (40+2t) since that was the initial volume + the flow in but then i thought about how the acutal vol change is just t when you account for the out flow.
as far as the concentration goes what i did was set up the D>E for the quantity of OH in the container then just divid q by (40+2t)
thanks for the help i sortof needed that conformation.
