D-Operator Homework Help: Understanding D^2 - 3D/5 Solved Example
  • Thread starter Thread starter DryRun
    Homework
5 replies · 1K views
DryRun
I'm reviewing my notes and i can't understand this part:
http://s1.ipicture.ru/uploads/20111202/OlsTV2UV.jpg
I have enclosed each corresponding term in the same coloured box. I've reviewed this solved example several times now but can't figure out how the result was obtained in the last line. I expanded each term (D^2 - 3D)/5 according to its power but ended up with terms exceeding powers of 3.
Hi sharks! :smile:
This is an application of Taylor's theorem.
In this particular case it means that:
1/(1+x)=1-(1/x)+(1/x)^2-...
It holds if |x| is less than 1, and also, in this particular case, it is the result of the corresponding geometric series.
I think you meant
[tex]\frac{1}{1+x}=1-x+x^2-x^3+\cdots[/tex] Anyway, that explains the second line, but sharks appears to be asking about the third.
Yes, that's what the dots are for... :smile: There are infinitely many terms in the second line too. The last term before the dots in the second line is included to make sure that all terms with D3 will be included in the last line. Higher order terms in the second line (the terms represented by dots) don't contain any Dn terms with n<4.
It's actually a Binomial series. And after some more digging around the net, i found the perfect example:
http://www.ucl.ac.uk/Mathematics/geomath/level2/series/ser84.html
Thanks for the help. I didn't know what it was, as i had just expanded the whole thing at first.
Cheers!
