What happens to the c2sin(t) part of the worked solution?
  • Thread starter Thread starter StillAnotherDave
    Damped Oscillator
The discussion centers on the solution of the damped oscillation equation $$\frac{d^2x}{dt^2}+4\frac{dx}{dt}+5x=0$$, specifically the term $$c_2sin(t)$$ in the general solution $$x(t)=e^{-2t}(c_1cos(t)+c_2sin(t))$$. The sine component is not explicitly part of the final solution due to its relationship with the phase constant $$\phi$$, which can be derived from trigonometric identities. The transformation between sine and cosine functions illustrates that they are phase-shifted versions of each other, allowing for simplification in the context of the equation of motion.
  • Understanding of second-order differential equations
  • Familiarity with damped oscillation concepts
  • Knowledge of trigonometric identities
  • Basic grasp of phase constants in oscillatory motion
  • Study the derivation of solutions for second-order linear differential equations
  • Explore the concept of phase constants in oscillatory systems
  • Learn about the application of trigonometric identities in physics
  • Investigate the implications of damping in oscillatory motion
Students and professionals in physics, particularly those focused on mechanics and oscillatory systems, as well as anyone interested in the mathematical foundations of differential equations.
StillAnotherDave
Why does the final solution of the equation of motion for damped oscillation not have a sine function?
$$x(t)=Ae^{-bt/2m} cos⁡(ωt+φ)$$
Hello folks,
So the solution of the equation of motion for damped oscillation is as stated above. If we were to take an specific example such as:
then the worked solution to the second order homogeneous is:
$$x\left(t\right)=e^{-2t}\left(c_1cos(t)+c_2sin(t)\right)$$
What happens to the $$c_2sin(t)$$ part of the worked soution? Why is it not part of the actual solution of the equation of motion?
Or does the sine function give the phase constant phi?
Aha, so:
{\displaystyle a\cos x+b\sin x=c\cos(x+\varphi )}
I didn't know this!
StillAnotherDave said:
Aha, so:
I didn't know this!
Your question was mostly trigonometry than physics. In the identity you give above it is $$c={\sqrt{a^2+b^2}}$$ and ##\phi## an angle such that $$\cos\phi=\frac{a}{\sqrt{a^2+b^2}},\sin\phi=\frac{b}{\sqrt{a^2+b^2}}$$
