What Is the Minimum Damping Constant to Limit Vibration Amplitude to 3.2 mm?
  • Thread starter Thread starter Firben
    Constant Damping
The discussion focuses on determining the minimum damping constant (c) required to limit the vibration amplitude of a 30 kg instrument to 3.2 mm when subjected to a forcing frequency of 0.8 Hz and an initial amplitude of 8.0 mm. The natural frequency (ωn) is calculated to be 8.165 rad/s (1.3 Hz) using the formula ωn = √(4k/m) with k = 500 N/m. The participants emphasize the importance of correctly identifying the forcing function and the effective spring constant when solving the differential equation governing the system's dynamics.
  • Understanding of harmonic motion and damping in mechanical systems.
  • Familiarity with differential equations, particularly for linear systems.
  • Knowledge of natural frequency calculations using mass and spring constants.
  • Ability to apply the formula for steady-state amplitude in damped systems.
  • Study the derivation and application of the formula for steady-state amplitude in damped harmonic oscillators.
  • Learn how to set up and solve ordinary linear constant-coefficient differential equations.
  • Research the effects of varying damping constants on vibration amplitude in mechanical systems.
  • Explore numerical methods for solving differential equations related to mechanical vibrations.
Mechanical engineers, physics students, and professionals involved in vibration analysis and control systems will benefit from this discussion.
Firben
A sensitive instrument with the mass of 30 kg should be installed in a labratory. In the labratory, there exist a machine that causes the floor to vibrate with the frequency of 0.8 Hz and with the amplitude 8.0 mm, each with the spring constant k = 500 N/m. Its then connected to a damper according to the figure.
http://s716.photobucket.com/user/Pitoraq/media/Mek22_zpsec302081.png.html
(note the 4 springs)Determine the smallest value that the damping constant c can have so that the vibration amplitude for the instrument due to the floors vibration never go over 3.2 mm
X = b(ω/ωn)^2/√[1-(ω/ωn)^2)^2+[2ζω/ωn]^2) (1)
ωn = √(4k/m) (2)
ζ = c/(2mωn) (3)
ω = 2πf = 5.026 rad/s
ωn = 8.165 rad/s
X = 8.0 mm
b = 3.2 mm
I started with (1) to solve for the damping factor ζ, but when i did that and plugged the values in i only got imaginary numbers. I am not sure if i done it right. Since i only need to know ζ to solve for c in (3)
0.8Hz is not the natural frequency. At the natural frequency, without damping, the amplitude would be infinite!
The frequency is 0.8Hz with and without damping. It's the frequency of the forcing function in your diff. equations.
Determine the forcing function necessary to produce an amplitude of 8.0 mm without the damper, then use that forcing function to determine c needed to reduce the amplitude from 8.0 mm to 3.2 mm.
P.S. I see only 2 springs. Are you sure there are four?
It doesn't look like the OP assumed 0.8 Hz as the natural frequency. According to his calculations, the natural frequency is 8.165 rad/s, which is equivalent to 1.3 Hz, as obtained from plugging the values m = 30 kg and k = 500 N/m into Eq. (2).
Looking at the diagram, you see only one view of the test apparatus. I think you can assume the test device has a spring at each corner.
I agree. I should have been more careful ...
Does anyone know how to solve this ?
What should i do ?
Should i solve for wn ?
The big question is whether your equations are correct. Either they're not or you made a math mistake somewhere.
The basic approach is to write the differential equation for the system: ∑ F = ma = mx''. Your initial conditions on x and x' are zero. You have a forcing function on x = xf = 8mm sinωt where ω = 2π(0.8 Hz).
I.e. you have something like mx'' + kx + cx' = m d2/dt2{xf}.
k is the EFFECTIVE spring constant. With 4 springs what would that be?
You then solve for x(t) and then solve that equation for c given x(t) = 3.2 mm max.
If you're not sufficiently familiar with ordinary linear constant-coefficient differential equations you'll have to either go with what you were taught or use the Web where there are lots of good analyses of this sort of problem. NOTE: you are interested in the STEADY-STATE solution only.
E.g http://hyperphysics.phy-astr.gsu.edu/hbase/oscdr.html
24K
