How to Achieve DC Biasing in a MOSFET Rectifier Design?
This discussion focuses on achieving DC biasing in a MOSFET rectifier design using the Synopsys simulator, specifically for a project targeting a technology node of 130nm and operating frequencies between 900MHz and 2.4GHz. Key design specifications include an input voltage range of 0.2V to 1.0V, a sensitivity of -32dBm, and a power conversion efficiency (PCE) greater than 80%. The conversation highlights the necessity for transistors to operate in the sub-threshold region for effective low-power rectification, emphasizing the importance of understanding subthreshold conduction in analog circuit design.
  • Understanding of MOSFET operation in sub-threshold region
  • Familiarity with Synopsys simulator for analog IC design
  • Knowledge of power conversion efficiency (PCE) metrics
  • Basic principles of rectifier design in high-frequency applications
  • Research techniques for DC biasing in MOSFET circuits
  • Learn about subthreshold conduction and its application in analog circuits
  • Explore Synopsys simulator tutorials specific to rectifier design
  • Investigate the impact of frequency on rectifier performance in the 900MHz to 2.4GHz range
Analog IC designers, electrical engineers, and students focusing on MOSFET rectifier design and low-power circuit optimization will benefit from this discussion.
Peiqii Tan
Hi there,
I m a beginner in Analog IC design field. Currently, I have a project which is to design a high sensitivity rectifier by using Synopsys simulator. However, I m stuck in the beginning part which is the DC biasing of MOSFET transistor.
The design specification as below:
Technology : 130nm
Frequency : 900MHz - 2.4GHz
input voltage : 0.2V - 1.0V
sensitivity : -32dBm
PCE : greater than 80%
1. How to do DC biasing? how to start it? Is any link can provide? Is it different with the amplifier design?
2. As mentioned in the journal, in order for rectifier to work with very low input power, all the transistors of rectifier should operate in the sub-threshold region. I m not clear with this part, suppose sub-threshold region will have no conduction path between drain and source. How could it able to trigger the transistor?
What journal?
From wikipedia: https://en.wikipedia.org/wiki/Subthreshold_conduction
"In digital circuits, subthreshold conduction is generally viewed as a parasitic leakage in a state that would ideally have no current. In micropower analog circuits, on the other hand, weak inversion is an efficient operating region, and subthreshold is a useful transistor mode around which circuit functions are designed"
You need to research and understand subthreshold analog circuits.
39K
  • · Replies 24 ·
9K
