DC Generator Output: Vmax, Poles, Ripples, EMF
The discussion revolves around the output characteristics of DC generators, specifically focusing on the mathematical representation of voltage output, the effects of the number of poles and commutator segments on output smoothness, and the interpretation of the EMF formula. Participants explore theoretical aspects, practical experiences, and the implications of different configurations in DC machines.
  • Some participants propose that the output of a DC generator can be represented as Vmax*|sin(2πft)| for 2 poles, suggesting that more poles lead to smoother output but still with ripples.
  • There is a question regarding whether the EMF expression, EMF = ϕ * (NZ/60) * (P/A), represents the maximum, rms, or mean value of the voltage.
  • One participant notes that the theoretical output will always have some ripple, regardless of the number of poles.
  • Another participant emphasizes that the commutator's role is to rectify the output, and more segments lead to a smoother DC output.
  • Concerns are raised about the assumptions in the formulas, particularly regarding the constant value of magnetic flux in practical applications.
  • Some participants discuss the practical implications of using voltmeters to measure output voltage in machines with many commutator segments, suggesting that this leads to a more constant reading.
  • There is mention of the relationship between the number of poles and the frequency of output, as well as the potential for shaping the flux to produce a flatter waveshape.
  • One participant suggests a mathematical approach to approximate real-world commutation by rewriting the formula in terms of degrees around the peak voltage.
Participants express differing views on the interpretation of the EMF formula and the effects of the number of poles and commutator segments on output characteristics. There is no consensus on whether the EMF expression represents a maximum or mean value, and the discussion remains unresolved regarding the implications of these factors on practical applications.
Participants highlight the importance of understanding the symbols used in the EMF expression and the assumptions made about magnetic flux. The discussion also touches on the limitations of theoretical models in capturing the complexities of real-world DC generator performance.
QwertyXP
1) My understanding is that the output of a DC generator has the form Vmax*|sin(2πft)| for 2 poles. Having more poles makes the output smoother but it would still have ripples. Is this correct?
2) In many places, I have seen the EMF of a DC generator written as: \phi * (NZ/60) * (P/A).
What value is given by this expression - is it the maximum, rms or mean value of the voltage?
1) Yes, it will always have some theoretical ripple.
What about the expression for EMF generated..does it represent the maximum or mean value?
I can't answer that part because I do not know what your symbols represent.
That would be a sinusoid, wouldn't it? Perhaps absolute value of one if I understand your symbols...
The commutator does its rectification (absolute value) by picking voltage at opportune time in the cycle
and generally the more commutator segments you have the more closely you will be to smooth DC output.
Observe on page 5 of your second link the two segment commutator provides only half wave rectification, which I would say is that first formula you posted. (fig 1.3A)
1.3B shows smoothing effect of more commutator segments.
When I took DC machines we went straight to the practical machines of the day with many commutator segments. We used the simpler equation for generated voltage Eg
Eg = K X \Phi X RPM
where K lumps several parameters and constants and can be calculated or measured . We had a lab where we did both.
It was easier to spin the machine and measure with a voltmeter than to disassemble it and measure physical dimensions and try to calculate flux.
Nowadays I see model airplane motors with three segment commutators, and automobile fuel pumps with five . Looking forward to your explanation of those;
old jim
Thanks for the reply, Jim. (Btw looks like "my" symbols seem to be alien over here!)
What I gather from ur reply is that when you worked with the DC machines, their output was nearly constant ("practical machines of the day with many commutator segments"). Therefore it was easy to use a voltmeter to see what the reading was.
But even the formula that you used assumes a constant value for magnetic flux (which it would be if the machine has lots of poles). But what about the 2-poles machine? It seems to me that EMF = ϕ * (NZ/60) * (P/A) or K X Φ X RPM would give the maximum value if we use the maximum value of ϕ (that the armature winding cuts during a rotation) in these expressions. Does it make sense?
The brushes pick off the voltage near the peak
see fig 6 here
http://www.reliance.com/mtr/mtrthrmn.htm
I think you are writing the formula for voltage in an individual winding
rather than after commutation
more poles just increases frequency for given RPM
and let's you add more brushes
The more commutator segments the nearer the peak you pick off the voltage
so the less ripple and the higher the mean
also they can shape flux under poles so as to produce a flatter waveshape than sine, but that's verging on the exotic details..
Your math is sharp
try rewriting your formula from absolute value of sine (two commutator segments)
to 360/n degrees either side of peak , where N = number commutator segments
I think that'll approximate real world commutation
and maybe that'll tie our formulas together..
i'm really not academic enough for this site, but do try to contribute on practical points
and I just love it when math and practicality converge
old jim
  • · Replies 38 ·
