DC vs AC Safety: What You Need to Know
  • Context: High School
  • Thread starter Thread starter adoado
    Ac Dc Safety
The discussion revolves around the safety of DC (Direct Current) versus AC (Alternating Current) electrical systems, focusing on the conditions under which each type of current can be considered dangerous. Participants explore the relationship between voltage, current, and the human body's resistance, as well as the implications for safety in practical scenarios.
  • Some participants express confusion about the general statement that "DC is safe, AC is dangerous," questioning the conditions under which electrical currents become harmful.
  • One participant argues that DC can be dangerous, especially at higher voltages (300-400 volts), while low voltage DC sources (like batteries) are generally safe.
  • Another participant emphasizes that the danger of electrical shock is more related to voltage than the type of current, noting that a 120 volt AC source can be harmful.
  • There is a mention of a threshold of approximately 50 volts for both AC and DC being considered dangerous, as it can push enough current through the body to cause harm.
  • Some participants discuss the role of body resistance in determining the current flow, with varying resistance values reported, suggesting that the 1500 Ω figure may not be universally applicable.
  • One participant shares a personal anecdote about the high voltage in a Chevy Volt, highlighting the risks associated with handling high voltage DC systems.
Participants do not reach a consensus on the safety of DC versus AC. There are multiple competing views regarding the dangers associated with each type of current, the significance of voltage, and the role of body resistance.
Participants mention that the effects of duration of exposure to electrical shock are relevant but not fully explored in the discussion. There is also uncertainty about the specific resistance values of the human body and how they impact current flow.
adoado
Hey guys,
My understanding of circuit analysis and the like is very minimal, and I have had a certain lack of understanding about something for a long time, and I feel I need to get a solid answer.
I understand the fundamental difference between a voltage or potential difference and a current, but I fail to see 'when' a combination of these becomes dangerous. The general statement I hear is 'DC is safe, AC is dangerous' but why? Is there a blanket current - x Amps, that is dangerous? And if so, why?
Cheers for reading!
Adrian
DC is not safe! I deal with DC power sources in the 300 - 400 volt range on a regular basis. I expect that if I ever become part of the circuit I will die.
In general the DC sources you will come in contact with are low voltage systems like flashlight batteries (1.5 volts) or car batteries (12.6 volts). These voltages will not force enough current through your body to be harmful. In general the AC power sources you will come into contact with are utilities. A 120 volt household circuit will force enough current through your body to harm you. The difference has nothing to do with AC vs. DC, it has everything to do with the voltage.
Voltage by itself is not particularly harmful. I could expose you to 10,000,000 volts and under the right conditions you will experience no ill effects and feel nothing. Current and duration must also be considered. The following chart addresses current...
I was unable to find information on the effects of duration but it obviously plays a roll. If the duration of an electric shock was short enough then there would be just 1 electron involved. 1 electron would need some bodacious voltage behind it to be harmful
Voltage is relevant in that it is the electrical pressure which causes current to flow. Ohms law states that I=V/R where I is current, V is voltage, and R is resistance. If a particular path through your body is 10,000 ohms then 1 volt will result in a current flow of .0001 amperes, that is not enough to even feel. You can also compute the amount of electrical power being dissipated by your body by multiplying the volts by the amperes, in this case it is 0.0001 watts. Now if 100 volts was applied to the same path it would result in a current flow of .01 amperes. According the the chart that's enough to be painful. Power flow in this case would be 1 watt. 10,000 times the first scenario. So you can see that power flow through your body will increase with the square of voltage.
AC current is much more safer than DC from what I know... On handling point of view DC could probably be safer...
Awesome, thanks a lot for the replies! Using your myspeedybob as a guide, I found this:
http://www.tpub.com/content/et/14086/css/14086_34.htm
It explains pretty much exactly what you said. So I guess as a general rule, assume the resistance of the body is R = 1500 Ω. Then, find the current by the voltage employed, and reference this to that chart?
no, read the previous post by Mr speedybob
in addition, any voltage over ~ 50V AC or DC is considered dangerous, as mr speedy bob alluded to, there is enough voltage to push enough current through you to kill you.
it only takes 30 - 40mA through the heart to put it into fibrilation and that doesn't matter if its AC or DC
Dave
The 1500Ω figure is meaningless. Depending on where I touch the leads to my skin my fluke reads anywhere from 500Ω to 90kΩ.
So the numbers on the bottom (in the log scale) are current in mA? What, then are the numbers on the left-hand side of each bar? What do the shaded areas represent?
adoado said:
Hey guys,
Cheers for reading!
Adrian
I understand that any voltage, AC or DC, being greater than 35 V is dangerous. DC sources are usually low voltage (i.e. battery) so for around the home the DC sources (batteries - less than 12V) are safe but the AC source (house wiring) is 120 VAC and dangerous.
By the way, I have a Chevy Volt. DC voltage of 1000 volts. I open the hood, pull back the insulator on two of the wires (+ and - on the 1000 volt supply) touch these two wires --- I die. The Chevy technicians that work on the Volt had to go through special training on how to handle the high voltage.
  • · Replies 26 ·
22K
