De Broglie's Wavelength (matter wave)
8 replies · 3K views
wavingerwin
Parallel beam of "cold" neutrons in the x-axis, with energy 0.1eV strikes a slit system in y-z plane.
Slits are parallel to the y-axis 1 micron apart. What will be the distance between the detector at x=20m which records the highest flux of neutrons, and the closest one to it that records nearly zero flux?
lambda = h/p
f = E/h
I tried to find lambda
going with
lambda = h/p
p = gamma*m*v
v = c*(1-(K/mc2+1)-2)0.5
with K = 0.1eV = 1.602e-20 Joules
m = 1.675e-27
I found v=0... since K2/mc2 << 1
What am I doing wrong?
Please help...
Thank you in advance
The neutron has a mass of almost 1 GeV. With a kinetic energy of only 0.1 eV, it's not moving at relativistic speeds, so just use p=mv and K=1/2 mv2.
I see :smile:.
So now that I have lambda = 9.04e-11 m
Can I use the equation (n-0.5)lambda = d sin(theta)
with n = 1
and x = 20 tan(theta)
so that x is the closest distance between the central maxima and the area of nearly zero flux?
I am concerned since the problem states that the neutrons go through a "slit system" and my tutor confirmed that this means that it has multiple slits, can I still use (n-0.5)lambda = d sin(theta) which I understand is mainly used for dual-slit?
if not, what equation should I use?
Since it says that the neutrons are in a "beam", can I say that even though there are multiple slits (1 micron apart), only 2 slits are playing a part in the problem?
thank you
What does the addition of more slits do to the interference pattern?
:shy:...It does not do anything...
I get it now that the 'slit system' is juts a diffraction grating and reading back my old notes about diffraction grating, the only difference is that now I cannot approximate sin(theta)=tan(theta)...
sorry about my silliness..
The pattern does change, and it has nothing to do with the approximation sin θ≈tan θ. That only requires that θ be small.
The positions of the maxima don't change, but the peaks become narrower, more well-defined.
Thanks vela..
the last part of the question says:
If the neutron come originally from a U-235 nuclear fission reactor, in what sense are they now "cold"?
I looked at wikipedia, and found "The neutron temperature, also called the neutron energy, indicates a free neutron's kinetic energy"
My guess is the neutrons are cold in the sense that they are traveling 'slow'.
Would that be right?
Again, thanks you for your time & patience in advance. :smile:
Yes, "cold" means "slow."
