DE constant coefficients and boundary conditions
25 replies · 4K views · last reply
AkilMAI
Find the solution of the equation
v''- 4v'+5v=0,such that v=-1 and v'=1 when x=pi=3.14159
I treat it as a polynomial=>r^2+4r+5=0
=>delta=-4=>r1=2+2i and r2=2-2i
v=e^[x+2](A*cos[2]+B*i*sin[2])
v=-1=e^[pi+2](A*cos[2]+B*i*sin[2])
v'=0...so I"m stuck and I need some help
This is NOT the characteristic equation of the d.e. you posted. Look at your original problem again.
Not "cos(2)", cos(2x)!
yes you are right,now I get this system
e^[pi+2](A*cos[2x]+B*i*sin[2x])=-1
2e^[pi+2](B*i*cos[2x]-A*sin[2x])=1...how can I solve it?
ok...
e^[pi+2](A*cos[2pi]+B*i*sin[2x])=-1=>e^[pi+2]*B*i=-1
2e^[pi+2](B*i*cos[2pi]-A*sin[2x])=1.=>2e^[pi+2]*A=1
how can I find A and B?
Well, the ODE is [itex]v''-4v'+5v =0[/itex]. The general solution I found is
[tex]v(x)= Ae^{(2+i)x} + Be^{(2-i)x}[/tex]
Now you'll get 2 equations from
[tex]v(\pi) = -1[/tex]
[tex]v'(\pi) = 1[/tex]
Can you spell them out again ?
A*e^((i+2)pi)+B*e^((i+2)pi)=-1
A*(i+2)*e^((i+2)pi)+B*(i-2)*e^(-(i-2)pi)=1...?
This is getting to be a mess. Let's start over again. The equation is v''- 4v'+5v=0, right? What are the roots of the associated quadratic?
AkilMAI said:
2+2i and 2-2i
That's your first problem. The imaginary part of those is wrong. How did you get it?
no,It is 2-i and 2+i...I calculated delta=-4=>r1=2-i and r2=2+i
Ok, and can you write, for example, A*exp((2-i)*x) in terms of the trig functions?
as in, e ^(2*x)*(P*cos( x) + Q*sin( x)),where P = A+B and Q = i(A−B)?
Yes, that's what I meant. So v=e ^(2*x)*(P*cos( x) + Q*sin( x)). Now you just have to put in your boundary conditions and find P and Q.
e ^(2*pi)*(P*cos( pi) + Q*sin( pi))=-1=>e ^(2*pi)*(-P)=-1
e ^(2*pi)*((2P+Q)*cos( pi) -(P- 2Q)*sin( pi))=1 =>e ^(2*pi)*(-(2P+Q))=1...multiplying ome of the wtih -1 is not going to help me solve the system
Your first equation tells you what P is. Put that into the second equation.
AkilMAI said:
if P=-1/e ^(2*pi)=>Q=1
You are being sloppy. What's P? You've got a sign wrong. And Q is way wrong. How did you do that?
I know I'm sloppy,is because I'm tired...P=1/e ^(2*pi)=>-e ^(2*pi)*((2/e ^(2*pi))+Q)=1
AkilMAI said:
=>Q=1/e ^(2*pi)-2/e ^(2*pi)
Take a rest. You are missing a sign again. Q=-1/e ^(2*pi)-2/e ^(2*pi). Note the first minus.
I will,but first this...so these are P and Q...I plug them into e ^(2*x)*(P*cos( x) + Q*sin( x))...and the result is the solution of the equation.
Sure.
