Decay pressure testing
  • Thread starter Thread starter ddudexyz
    Bluetooth Usb
The discussion centers on conducting pressure decay testing with a focus on a 10-minute test duration and electronic transmission of results to a storage location. Key recommendations include utilizing a Programmable Logic Controller (PLC) from manufacturers such as Allen-Bradley, Texas Instruments, or Siemens for data logging and measurement. The conversation emphasizes the importance of specifying the type of pressure measuring equipment, available communication ports, and the desired logging method, whether it be to a printer or a digital storage device. Clear definitions of the setup and requirements are crucial for effective advice.
  • Understanding of Programmable Logic Controllers (PLCs)
  • Familiarity with pressure measurement equipment and communication ports (USB, Ethernet, Serial/RS-232)
  • Knowledge of data logging methods and storage devices (HDD, SSD)
  • Basic principles of pressure decay testing
  • Research the specifications and capabilities of Allen-Bradley, Texas Instruments, and Siemens PLCs
  • Learn about different types of pressure sensors and their communication interfaces
  • Explore data logging software options compatible with PLCs
  • Investigate methods for electronically transmitting data to storage solutions
Engineers, technicians, and researchers involved in pressure testing, automation, and data logging who seek to implement effective pressure decay testing solutions.
ddudexyz
TL;DR
Transference of information electronically to alleviate human error
I want to conduct pressure decay testing that will conduct a decay test lasting 10 mins and once the test has concluded transmit test result electronically to a saved storage location. Any advice?
Welcome to PF.
There are lots of ways to measure and log data. Do you have experience with any such methods and equipment?
Can you link to the datasheet for your pressure measuring equipment? Does it already have some electronic communication port for communicating with it? (USB, Ethernet, Serial/RS-232, etc.)
What kind of PC do you have to read and log the data? What communication ports does it have available?
The more you tell us about your setup, the more we can help you get this up and running soon. :smile:
The entire idea is at ground level right now. Assume I have absolutely nothing to start with. What advice would you give to construct a simple, but effective means by which to obtain the desired result?
To be honest, your response makes no sense. What *exactly* are you trying to do?
In keeping with the "Limited Information Transfer" in this thread, I suggest a Programmable Logic Controller, or PLC as they are often called.
The three major manufacturers are: Allen-Bradley, Texas Instrument, Siemens. Input interfaces available include: On-Off Voltage (AC & DC, Analog Voltage (AC & DC), 4-20mA Current; along with a multitude of sensors from various manufacturers.
You mention Logging. Does this mean to a printer, graphic display, mass storage device (what kind? hard disc drive, Solid State Drive, other?)
So far you are asking on the order of "I want to make marks on paper." That could be a $4000 high speed line printer down to grab a piece of charcoal and draw a line.
For instance you could use a bellows, a pencil, and have the pencil poke a hole in the paper when the pressure gets too low. That meets your stated constraints.
So far, we have no idea what you think you need or how it is to be presented as useful information.
If you want targeted answers, further define the problem and your constraints.
Cheers,
Tom
  • · Replies 0 ·
  • · Replies 27 ·
