What is the deceleration of a snowboarder going up a 5.0° slope?
The deceleration of a snowboarder going up a 5.0° slope is calculated to be 1.83 m/s², based on the coefficient of friction for waxed wood on wet snow, which is 0.1. The analysis reveals that both gravitational force and kinetic friction act against the snowboarder's motion, leading to a net force that results in deceleration. The normal force is calculated as 9.8 N for a mass of 1 kg, and the force parallel to the slope is derived from the gravitational component, 9.8 sin(5°) = 0.854 N. The confusion arises from misinterpreting the direction of forces; both the gravitational component and kinetic friction oppose the snowboarder's upward motion.
  • Understanding of Newton's Second Law of Motion (F = ma)
  • Knowledge of gravitational force calculations (W = mg)
  • Familiarity with friction concepts, specifically kinetic friction (Fk = k * Fn)
  • Basic trigonometry for calculating forces on inclined planes
  • Review the principles of inclined plane physics and force decomposition
  • Study the effects of different coefficients of friction on motion
  • Learn about the role of normal force in various scenarios
  • Explore advanced topics in dynamics, such as energy conservation in motion on slopes
Students studying physics, particularly those focusing on mechanics and dynamics, as well as educators seeking to clarify concepts related to forces on inclined planes.
ThePiGeek314
Calculate the deceleration of a snowboarder going up a 5.0° slope, assuming the coefficient of friction for waxed wood on wet snow ( = 0.1).
F = ma
W = mg
Fs = (Fn)
Fk = k (Fn)
Answer key says it's 1.83 m/s2. I fiddled around with the numbers I got and I was able to get the right answer, but I don't understand why it's the right answer. Below is my work.
Normal force = 9.8 (assuming the snowboarder has a mass of 1 kg)
Force pushing the snowboarder UP the hill: 9.8 sin (5 degrees) = 0.854 (Is this right?? Is there a force pushing him up the hill??)
Kinetic friction = * Fn = 0.1 * 9.8 = 0.98 N
Sum the horizontal forces, applying Newton's Second Law of Motion...
a = (∑Fx) / m
(a = acceleration, Fx = all horizontal forces, m = mass)
Because the 0.854 is the force pushing him up the hill, and the kinetic friction works opposite to that, I subtracted the kinetic friction value from the 0.854. So...
a = (0.854 - 0.98) / m......(m is assumed to be 1)
a = -0.126 / 1
a = -0.126 m/s2
But if I simply add the two force values that I found - add the kinetic friction and the force parallel to the hill -- I get 1.834, which is the correct answer. That means that my assumption that 0.854 N was pushing the snowboarder up the hill was wrong. So both the 0.854 N and the kinetic friction must be working in the same direction.
But if there's no force pushing him up the hill, and I'm not given an initial velocity up the hill, then how can there be any motion at all? He'd be going down the hill, not up it.
Please explain why the 0.854 N and kinetic friction are working in the same direction, since kinetic friction is supposed to work in the opposite direction of the attempted motion.
Only on a horizontal surface.
You don't have to assume a mass. Just use m as mass, it will cancel in the calculations.
Then you can also work with units, which makes it easier to spot mistakes.
Where would such a force come from?
Both gravity and friction slow down the snowboarder, they are both against the direction of motion. There is no force pushing anyone upwards.
Got it - because the 0.854 N was calculated as a function of the force of gravity - 9.8 sin Θ, so it's the gravitational force pulling the skier down the hill. Thank you!
  • · Replies 26 ·
  • · Replies 31 ·
