Deceleration Parameter Computation
The discussion focuses on computing the deceleration parameter (q_0) for a radiation-dominated universe. The participants clarify that q_0 is derived from the second derivative of the scale factor and its relationship to density parameters. It is noted that the value of Ω_rad provided (8.2 x 10^-5) is not suitable for a radiation-dominated scenario, as this universe should have Ω_rad close to one. The correct approach involves using the scale factor a~t^1/2 and its derivatives to derive q_0, with attention to the negative sign in the calculations. Overall, the conversation emphasizes the importance of correctly applying the equations related to a radiation-dominated universe.
roam
Hi everyone,
Can anyone point me into the right direction on how to compute the deceleration parameter (##q_0##) for a radiation dominated universe?
I know that q0 is given by
##q_0=-\frac{\ddot{a}(t_0)}{a(t_0) H^2 (t_0)} = - \frac{\ddot{a}(t_0) a(t_0)}{\dot{a}^2(t_0)}=\frac{\Omega_0}{2}##​
So for a radiation dominated universe, we have ##\omega = + \frac{1}{3}##. And ρ~1/a4, and a~t1/2. I'm not sure how to relate this to that equation.
My notes say ##\Omega _{rad} = 8.2 \times 10^-5## but I'm not sure how this was calculated. How do I compute Ω0=ρ/ρcrit in this case? I know that ρcrit=3H2/8πG, but what is the density ρ? :confused:
Using that value I get the following but I'm not sure if it's correct:
##q_0 = \frac{\Omega_0}{2} = \frac{8.2 \times 10^-5}{2} = 4.1 \times 10^{-5}##.
I couldn't find any info on this computation online. So any help is greatly appreciated.
Space news on Phys.org
You have a(t), and since H(t) = \dot{a}(t)/a(t) and q(t) is fully determined by a(t), you should be good to go...
Your value for \Omega_{rad} is the current radiation density in the actual universe, which isn't radiation dominated and not appropriate for use with w=1/3, etc.
Likes 1 person
Thank you for the clarification regarding ##\Omega##, it makes perfect sense now.
But I'm still not sure how the calculation goes (my book lacks any worked problems) :confused:
Since for a radiation dominated universe we had the scale factor a~t1/2, with its time derivatives ##\dot{a}=\frac{1}{2 t^{1/2}}##, and ##\ddot{a}=\frac{-1}{4t^{3/2}}##, then
##q_0 = \frac{\ddot{a}}{a \left( \dot{a}/a \right)} = \frac{-1}{16t^{6/2}}##
Is this correct?
A radiation-dominated universe is one where \Omega_{rad} is very close to one. I haven't checked your math at all, but hopefully that helps you get the right answer.
Likes 1 person
A radiation-dominated universe has positive deceleration (negative acceleration).
Is this correct?
You forgot the initial minus sign.
Likes 1 person
Thank you very much. :)
  • · Replies 22 ·
  • · Replies 17 ·
