High School How can I perform decimal computation by hand?
  • Thread starter Thread starter Mr Davis 97
    Computation hand
To perform the computation (120)(54.30/194.79) by hand, first simplify the expression to (120 * 54.30) / 194.79. The multiplication of 120 and 54.30 is straightforward, while the division requires long division techniques. To estimate the decimal, multiply the numerator by 120 and then divide by 19479, resulting in a quotient of 33 with a remainder. The remainder can be approximated to determine the decimal value, which is essential for achieving the final answer of 33.45. Understanding long division is crucial for accurately calculating the remainder and converting it into a decimal.
Mr Davis 97
I have to perform the following computation by hand to get a number within two decimal places:
##\displaystyle (120)(\frac{54.30}{194.79})##. The answer is 33.45, but how can I do this by hand?
Mathematics news on Phys.org
Well, the multiplication part should be easy enough. It's the long division which takes a bit more effort.
Remember, $$a ⋅ \frac{b}{c} = \frac{a ⋅ b}{c}$$
Don't tell me you've never done any arithmetic by hand.
multiply top and bottom by 1 ie 100/100 to get 120 * 5430/19479
next use long division
You could first multiply the numerator by 120 before you divide
Okay, so doing the long division ##\frac{651600}{19479}## I can get to 33, but then I have the remainder ##\frac{8793}{19479}##. How can I figure out that this remainder is approximately 0.45?
Have you forgotten how to do long division?
Here's an example image:
Here's some video tutorials to help you:
and there are more here:
https://dl.dropboxusercontent.com/u/28928849/Webpages/ArithmeticVideoLibraryTable.htm
from mathispower4u.com
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 18 ·
