Definite integral evaluation (Inverse Fourier Sine Transform)
The integral evaluation discussed is \int_0^{\infty}\ \left(e^{-k^2 t}/k\right)\sin(kx)\ dk, which is solved using Mathematica to yield \frac{\pi}{2}Erf[x/2\sqrt{t}]. The discussion highlights the potential application of convolution theorems and the transformation of the sine integral into an exponential form to facilitate the evaluation. A key suggestion involves differentiating the function f(x,t) = \int_0^\infty \frac{e^{-k^2 t}}{k}\sin kx\,dk with respect to x to simplify the integral.
  • Understanding of inverse Fourier transforms
  • Familiarity with error functions (Erf)
  • Knowledge of integral calculus, specifically improper integrals
  • Experience with Mathematica for symbolic computation
  • Learn about convolution theorems in Fourier analysis
  • Study the properties and applications of the error function (Erf)
  • Explore differentiation under the integral sign techniques
  • Investigate the relationship between sine and exponential integrals
Students and professionals in mathematics, particularly those focused on integral calculus, Fourier analysis, and mathematical physics.
tjackson3
I'm working on a long problem and have come to the final step. The answer seems so simple, but I can't quite get to it. I need to evaluate this integral:
Mathematica gives the result as \frac{\pi}{2}Erf[x/2\sqrt{t}].
The answer makes me think that there is some kind of convolution theorem at work here (even though there isn't a direct one for the Sine Transform), since \int_0^{\infty}\ \sin(kx)/k\ dk = \pi/2. I can't for the life of me get that error function to come out, though. I've tried playing some with the convolution theorem dealing with the Cosine Transform, but that doesn't seem to get me anywhere. I tried converting to exponential form, since that seems like the logical way to get at the error function, but I'm left with the following integral:
\Im\left[\int_0^{\infty}\ e^{-t(k-(ix/2t))^2}/k\ dk\right]
The trouble is, if you do the typical thing of making a u substitution, you can't get rid of the k in the denominator, and I don't know how you'd separate the imaginary component. Any tips? Thank you so much!
I think that last integral may be the right way to do it, since
\int_0^{\infty}\ e^{-k}/\sqrt{k}\ dk \propto Erf(\sqrt{k})
I haven't tried working the problem out completely, so this is just a suggestion. Let
$$f(x,t) = \int_0^\infty \frac{e^{-k^2 t}}{k}\sin kx\,dk.$$ If you differentiate with respect to x, you'll get
$$\frac{\partial f}{\partial x} = \int_0^\infty e^{-k^2 t}\cos kx\,dk,$$ which doesn't have the pesky k in the denominator. Perhaps it would be easier to solve for ##\partial_x f## and integrate the result.
That worked beautifully, vela. Thank you!
