Definition of sequence and series
The discussion centers on the definitions of sequences and series, highlighting variations in definitions found in different texts. A sequence is generally defined as a function mapping positive integers to real numbers, while a series is defined as the sum of a sequence's partial sums. It is clarified that starting a sequence from any positive integer, such as k0, does not affect the validity of theorems related to sequences, as they can be shown to be equivalent through index shifting. The root and ratio tests for convergence can also be applied to series starting from any integer k0, as the definitions remain consistent for practical purposes. Overall, the key takeaway is that different starting points for sequences do not hinder the application of mathematical concepts and theorems.
gotjrgkr
Hi!
While studying sequence and series, I've gotten some misunderstandings in the definitions of sequence and series.
What I know about the definitions of sequence and series is as follows below
; a sequence of field of real numbers is defined as a function mapping of the set of all positive integers into the field , and a series of real field is defined to be a sequence whose range consists of partial sums \sum ^{k}_{n=1}a_{n}.
But, in some other books, the definitions of them are a little different from what I've written as above. I mean that in some books, they give a function from { k\in Z : k\geqk_{0} for an integer k_{0}} into the real field as a definition of a sequence.
What i'd like to ask you in this situation is whether there're no problems even if I use the different definitions of a sequence when I prove all theorems relating with the sequence ;
for example, Bolzano-weierstrass theorem, additivity of limit of two sequences, etc.
Furthermore, when we test the convergence of a series of some sepecial kinds, as you know, we usually use root, ratio tests. At first, I've learned that this tests are used when the sequence of a series runs from 1 to infinity. But, I recently found in some books that those methods are also used in determining the convergence of series running from some integer k_{0} into infinity. That means the sequence of the series starts from the integer k_{0}.I want to ask you if the root or ratio test can be used even in dealing with the series whose sequence runs from a integer k_{0}. If so, I also ask you the rigorous definition of series of this kind \sum^{infinity}_{n=k_{0}}a_{n}.
Thank you for reading my long questions.
I'll wait for your answers!
God bless you! Have a nice day!
Whether you start your sequence at 0, 1 or any other positive integer k0 does not matter. It is an easy exercise to prove that they are equivalent (basically finding a bijection is enough - and the bijection is just shifting the index by k0).
You can define an "infinite" series as the limit of the partial sums:
\sum_{n = 0}^\infty a_n = \lim_{N \to \infty} \sum_{n = 0}^N a_n
Do you mean that I can reach to the same theorem (but the definition of sequence in the theorem is a little different) concerned with a sequence even though I use different definitions of a sequence ??
In the above equation, does the symbol N run from 0? or 1?
Yes, because I claim that the definition is equivalent for all practical purposes as they are related by a simple shift.
I don't really understand the second question... N is the limit variable.
What I know about the definition of limit of a given sequence <b_{N}>( it starts from 1;b_{1},b_{2}, ...) is as follows; the sequence <b_{N}> converges to b_{0} if for any \epsilon>0, \existsM>0 such that N>M implies \left|b_{N}-b_{0}\right|<\epsilon.
In the above equation you show me, it's a limit of a sequence <b_{N}>=\sum^{N}_{n=0}a_{n}. If the sequence <b_{N}> starts from 1, then I can apply the definition of limit of a sequence to this sequence. But if the sequence <b_{N}> starts from 0, then it's confusing for me to apply the definition of limit of sequence as I mentioned above. But You told me that it doesn't matter whether I use different definitions of a sequence. So I wonder if in the case of the sequence <b_{N}> there's another definition of limit of sequence, too. ;;Because of this I'm confused .
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 17 ·
