Deflection in a Simply supported beam
pukb
Hi All
As shown in the attached image, I have a simply supported beam with a load of 150kN acting at the center of the beam span.
E = 210 GPa
rho = 7800 kgm-3
span = 250 mm
After solving this in FE solver, I got maximum displacement to be ~4mm (at node 52)
But, on using the theoretical relation of delta = P* l^3 / (48*E*I), it is about ~11mm.
Can somebody please help me on this ? how to co-relate this.
Some observations:
1. There is no hourglassing.
2. Beam looks compressed by about 0.8mm at the center at the end of solution.
  • FE mesh of a simply supported beam drawn as a rectangular grid of quadrilateral elements, with pin supports at both ends and labelled nodes N.25 at the top and N.52 at the bottom of the midspan.
Just eyeballing your problem, it appears you have a short, deep beam with a central load applied. The standard beam formulas for deflection are generally applicable to long slender beams where shear deflection doesn't need to be taken into account. The standard formulas are also approximations which assume that the slope of the beam in the deflected condition is very small. Without knowing more about the cross section of you beam, I can't provide any more insight into your dilemma.
pukb said:
Hi All
E = 210 GPa
rho = 7800 kgm-3
span = 250 mm
Some observations:
pukb said:
Cross section:
Thickness = 2mm
height = 50 mm
Doing some simple calculations, your simply supported beam is wildly overloaded, with the calculated bending stress lying far outside the elastic range for the material used to construct it. Therefore, any deflections you are calculated using the deflection formula for a simply supported beam are certainly incorrect. The deflection your FE solver is giving you is suspect as well: this beam should probably have snapped in two.
Code:
Beam test:
L = 250 mm
depth = 50 mm
width =   2 mm
E = 210 GPa
P = 150 kN @ L/2
Simple supports
M = PL/4 = 150 kN * 0.25/4 = 9375 N-m
d = PL^3/(48EI)
I = (1/12)*0.002*0.05^3
I = 2.083E-8 m^4
d = 150000(0.25)^3/(48*210*10^9*2.083*10^-8)
d = 0.0111 m = 11.1 mm deflection
sigma = My/I = 9375 * 0.025 / 2.083*10^-8
sigma = 1.125*10^10 Pa = 11.25 GPa bending stress
yield strength = 186-758 MPa for steel
1 MPa = 145 psi
yield strength = 26970 - 109910 psi for carbon steels
