Density of Electrons inside cylinder wire
The discussion centers on the density of electrons within a cylindrical wire, particularly focusing on how current distribution varies between direct current (DC) and alternating current (AC). It is established that for AC currents, the current tends to be confined to the surface of the conductor due to the skin effect, while for DC currents, the electron density remains uniform across the wire's cross-section. The resistivity of copper is noted as approximately 17 nano-ohm-meters, with a calculated resistance of 2.17 ohms for a 100-meter long, 1 mm diameter copper wire. The skin depth, which affects current penetration, is inversely related to frequency, becoming significant at low frequencies around 10 kHz.
  • Understanding of electrical current concepts, specifically DC and AC.
  • Familiarity with skin effect and skin depth in conductors.
  • Knowledge of resistivity and resistance calculations, particularly for copper.
  • Basic grasp of electromagnetic wave behavior in transmission lines.
  • Research the skin effect and its implications on current distribution in conductors.
  • Study the characteristics of transmission lines, focusing on impedance calculations (Z = sqrt(L/C)).
  • Explore the relationship between frequency and inductance in coaxial cables, such as RG-8.
  • Investigate the effects of varying voltage across the cross-section of a wire on electron density.
Electrical engineers, physicists, and students studying electromagnetism and circuit design will benefit from this discussion, particularly those interested in current behavior in conductive materials.
Mahbod|Druid
Hi
assume J = I/A = equal in a circular segment of wire
then after a while those electrons forces other electrons to come closer to center but not all of them
(some thing like Haal effect (spell?) )
I want to find out the function of Density of electrons--Distance from center of wire
in books they assume all the electrons move in a line but actually they don't in my Question
https://www.physicsforums.com/showthread.php?t=313514"
They will be more or less uniformily distributed on the surface.
on surface ?
but Wire has not any Extra charge so why should electrons go on surface ?
Sorry, the currents will be confined to the surface. The electrons on the interior will more or less be unaffected.
The resistivity of copper is about p = 17 nano-ohm-meters. Therefore the resistance of a copper wire L= 100 meters long and .001 meter diameter (A= 7.85 x 10-7 m2) is
R = pL/A = 2.17 ohms.
This assumes the current is flowing uniformly throughout entire cross section of wire. This value agrees with my table of wire resistance for 18 gauge wire. The resistance would be much higher if the current flowed only on surface. In fact, the depth of the current penetration toward the center of the wire depends on the inverse square root of frequency, and is called the skin depth. See
http://en.wikipedia.org/wiki/Skin_depth
If it was a perfect conductor (zero resistance/infinite conductance) then the current would flow only on the surface. The conductivity of copper is on the order of 10 M-mhos. So I would say you need to get down to low frequencies, like on the order of the 10 kilohertz before you hit a skin depth on the order of 1 mm.
If he is talking about DC currents then that would be an interesting thought exercise. With the voltage source sourcing and sinking the charges then there wouldn't be a charge differential setup to cancel out the applied electric field like we normally would assume in electrostatics. I would assume that the current will then be more or less distributed evenly throughout the wire. But under those conditions then the electron density will be uniform, just moving.
So I think the answer remains the same. With AC currents, the current is confined to surface of a perfect conductor and for a good conductor until you hit around the very low frequencies. And for DC the current is uniform I think (provided you can apply a uniform voltage across the cross-section of the wire) so in both cases the electron density is mostly uniform. Between DC and VLF things get sketchy, it would depend upon the frequency for the most part. The currents will not be uniform or symmetric through the cross-section of the wire. I remember seeing an applet that showed the EM wave for a twisted pair at a given frequency. It would be nice if I could find that again as it would give an idea of how the currents are.
But as for the charge distribution, I'm not sure. The voltage source is sourcing and sinking the charges so I'm not sure how to relate the EM waves of a transmission line and the charge distribution inside the conductors. We generally assume that the medium is source free when we solve the wave equations and so analysis of the electric field will not yield a charge distribution, I don't think.
I remember measuring the inductance per unit length of a coaxial transmission line, specifically RG-8. Below about 100 kHz the inductance was higher than the inductance above about 1 MHz. The inductance at low frequencies includes magnetic fields inside the center conductor, which are excluded at high frequencies. Because capacitance is a surface property, the charactistic impedance of RG-8 (Z = sqrt(L/C) ) dropped by roughly an ohm or so.
Note: The characteristic impedance of a transmission line is Z = sqrt(L/C) where L is the inductance per unit length, and C is the capacitance per unit length.
What's your point?
  • · Replies 20 ·
  • · Replies 19 ·
11K
