Derivation of Dirac Delta Function
The discussion focuses on the derivation of the Dirac delta function using the integral expression 1/(2π) ∫ e^(ikx) dk. Participants clarify that this integral does not exist in the traditional sense learned in calculus, as it involves distributions rather than standard functions. They emphasize that the integral can be interpreted through the context of distributions, leading to the result that for smooth, rapidly decreasing functions f, the integral evaluates to f(0). The conversation also touches on the limit of sin(nx)/(πx) as n approaches infinity, which is another representation of the delta function. Ultimately, the participants conclude that while the integral may not be solvable in a conventional way, it holds significance within the framework of distribution theory.
coki2000
Hello,
My question is about how dirac-delta function is derived by using this integral,
\frac{1}{2\pi }\int_{-\infty}^{\infty}e^{ikx}dk=\delta (x)
I couldn't solve this integral. Please help me.
Thanks for all of your helps.
The trick is that that's not an integral, at least not of the sort you learned in Calc 2.
Unfolding all the definitions involved, what they really mean is that
<br /> \frac{1}{2\pi }\int_{-\infty}^{+\infty}\int_{-\infty}^{+\infty}e^{ikx} f(x)\, dx \, dk=f(0)<br />​
for any f which is smooth and rapidly decreasing. (Or some similar condition, depending on the precise details of what they're doing)
OK, but how can I solve this integral? Actually, I wonder it.
You can't.
Read Hurkyl's response again.
If they are using the \int symbol to denote the sort of integral you learned in your Calc 2 class, then that integral doesn't exist.
But when I try to integrate it, I take this answer,
\lim_{n \to \infty}\frac{sin(nx)}{\pi x}=\delta (x)
It should have a meaning.
No, it does not.
Okey thanks for your helps.
You're welcome.
  • · Replies 25 ·
  • · Replies 32 ·
