Derivation of Hamilton's Principle: Questions
The discussion revolves around the derivation of Hamilton's Principle, focusing on the origins of specific equations used in the derivation process. Participants explore the connections between Hamilton's Principle, d'Alembert's principle, and the equations of motion, while seeking clarity on the assumptions and steps involved in the derivation.
  • One participant expresses confusion about the origin of the equation m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0 and its role in deriving the action integral.
  • Another participant suggests that the left-hand side of the equation is a total derivative and discusses its implications under certain conditions.
  • Concerns are raised about the circular reasoning in assuming Hamilton's Principle while trying to derive it from another equation.
  • Some participants mention the importance of the condition that virtual displacements vanish at the endpoints in the context of Hamilton's Principle.
  • One participant critiques the notation and mathematical expressions used in the referenced paper, questioning their validity.
  • Several participants recommend classical texts and papers for further reading on the derivation of Hamilton's Principle.
Participants do not reach a consensus on the validity of the equations presented in the paper or the clarity of the derivation process. There are multiple competing views regarding the assumptions and steps necessary to derive Hamilton's Principle.
There are unresolved questions about the mathematical steps and definitions used in the derivation, particularly concerning the treatment of virtual displacements and the assumptions made in the referenced paper.
This discussion may be of interest to students and researchers in classical mechanics, particularly those looking to understand the derivation of Hamilton's Principle and the underlying principles of Lagrangian mechanics.
PhysicsLama
TL;DR
I want to know how the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## can be derived, because it is a key part in understanding how hamiltons principle can be derived.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term
##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the action-integral can be derived.
If needed I can add the steps from how to get from (1) to (2).
The paper from where I took (1) is the following: https://www.researchgate.net/public...ple_for_the_Derivation_of_Equations_of_Motion
Thanks for your help
No it is just a part of some little-known text
Do you know where that equation came from?
Welcome to PF.
I confess I didn't have the patience to read the linked paper. Yet, here is my take. Tell me whether it answers your question.
We don't have$$m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0$$as you wrote in post #1. But we note that the LHS is a total derivative, so in the absence of ##~\mathbf{F}_i~## we get from equations (1)-(4) in the referenced paper:$$\delta \int_{t_1}^{t_2}L~dt=m\int_{t_1}^{t_2}\frac{d}{dt} (\frac{dr}{dt}\delta r)~dt = m\left[\frac{dr}{dt} \delta r\right]_{t_1}^{t_2} \quad.$$If we impose$$\delta r(t_1)=0=\delta r(t_2)$$(which we do!), the RHS is zero. This is just what we need in order to proceed.
edit:
The vanishing of ##~\delta r~## at the endpoints is certainly a key ingredient in Hamilton's principle.
JimWhoKnew said:
Welcome to PF.
edit:
Thanks for your answer.
Now the thing I do not understand is how to even derive the LHS from equation (4) (in the paper). Even if we look at your explanation we still take the Hamilton Principle
##\delta \int L \; dt = 0##
for granted and just put in equation (4). But to derive the Hamilton Principle with the logic of this paper we need the term on the LHS of (4). My Problem is that I don't understand where the LHS of equation (4) in the paper is taken from, without one knowing the form of Hamiltons Principle (like you did), which we can't use because we are deriving it from (4). For me it's like trying to proof a theorem by using the theorem.
Thanks for your help already in advance :)
So am I. Actually I looked through it and found it turbid. Heaps of excellent classical texts are devoted to the topic.
Okay thanks for the time. Do you have any names for those classical texts?
Paul Appell: Traité de mécanique rationnelle vol 1,2
Greenwood D.T. Classical dynamics
Jorge V. José, Eugene J. Saletan Classical Dynamics A Contemporary Approach
Pars, L. A A treatise on the analytical dynamics
At which point of the paper do you believe the author takes ##\delta \int L \;dt = 0## for granted?
The paper starts with d'Alembert's principle in the form of equation (1) of the paper. Equation (4) is used to make a substitution in (1) to derive the "extended Hamilton's principle", equation (8): ## \int_{t_1}^{t_2} (\delta L + \delta W) \;dt = 0##.
I don't see any circular reasoning by the author in getting to (8).
In addition to @TSny's explanation in #9: the usual practice is to assume ##\delta ~\int L~dt = 0~## , and derive the equations of motion from it. In the paper, they try to motivate this practice (I think), so they go in the opposite direction (as it developed historically): they start from d'Alembert's principle (equation (1) ) and work their way to show that it yields ##\delta ~\int L~dt = 0~## . Note that equation (1) is satisfied for all ##~\delta \mathbf{r}_i~## only if all the terms in brackets are zero, and this happens only when Newton's second law is satisfied. So we may say that the starting point is Newton's law.
Equation (4) is nothing but a straightforward mathematical manipulation. You don't need to "derive" the LHS, you only have to show that it equals the RHS, which they do. Now it can be used, along with the endpoints condition, to get $$\delta \int_{t_1}^{t_2}L~dt=m\int_{t_1}^{t_2}\frac{d}{dt} (\frac{dr}{dt}\delta r)~dt = m\left[\frac{dr}{dt} \delta r\right]_{t_1}^{t_2}=0 $$as intended.
Clearer?
There are plenty of good books on this subject.
Feynman's lecture is accessible for free.
Goldstein's "Classical Mechanics" has been a canonical text for decades.
Edit: rephrased a little.
Formula (4) from the article merely does not make sense. Indeed,
in the text above ##\delta\boldsymbol {r}_i## stands for virtual displacements. By definition a virtual displacement is a vector from some vector space and we know how this vector space is defined, that is ok.
In the notation ##\delta\boldsymbol {r}_i## the letter ##\delta## is not an operation it is a part of the symbol. For example we can use ##\boldsymbol \xi_i## to denote virtual displacements.
In formula (4) ##\boldsymbol r_i(t)## is a real motion of the system.
The term
$$\delta\frac{d\boldsymbol r_i}{dt}$$ is a nonsense.
Formulas like that (which the author uses implicitly):
$$\delta\Big(\frac{d\boldsymbol r_i}{dt}\cdot \frac{d\boldsymbol r_i}{dt}\Big)=2\frac{d\boldsymbol r_i}{dt}\cdot \delta\frac{d\boldsymbol r_i}{dt}$$
are the nonsense as well.
Okay thanks guys I think I have undertstood better now. But do you have any Papers or Books where I specificely could read something directly about how to derive Hamiltons Principle, so how to derive that ##\delta \int L \; dt## (A), not how to get from Hamiltons Principle to the equations of motion but how to basically get to the Hamilton Principle. In all the books and papers you suggested like the Feynman lectures or Greenwoods classical dynamics for instance the Hamilton Principle (A) was just given to be true and never derived somehow mathematically. The paper I linked was the only one I found online specific explaining how to derive (A) but it seems to be a not very good written one and even an at least partly wrong one.
to get to the Hamilton Principle from what?
The standard scheme is as follows.
(the Lagrange-D'Alambert principle+certain assumptions) ##\Longleftrightarrow## (the Lagrange equations) ##\Longleftrightarrow## (the Hamilton principle)
The term
How do you derive Euler-Lagrange equations from Hamilton's principle without using$$\delta\frac{d\mathbf{r}_i}{dt}$$and without replacing it by$$\frac{d}{dt}\delta\mathbf{r}_i$$?
$$L=L(t,x,\dot x);\quad\frac{d}{ds}\Big|_{s=0}\int_{t_1}^{t_2}L\big(t,x(t)+s\xi(t),\dot x(t)+s\dot \xi(t)\big)dt$$
$$=\int_{t_1}^{t_2}(L_x\xi+L_{\dot x}\dot\xi) dt=
L_{\dot x}\xi\Big|_{t_1}^{t_2}+\int_{t_1}^{t_2}\Big(L_x-\frac{d L_{\dot x}}{dt}\Big)\xi dt$$
  • Love
wrobel said:
$$L=L(t,x,\dot x);\quad\frac{d}{ds}\Big|_{s=0}\int_{t_1}^{t_2}L\big(\tau,x(\tau)+s\xi(\tau),\dot x(\tau)+s\dot \xi(\tau)\big)d\tau$$
$$=\int_{t_1}^{t_2}(L_x\xi+L_{\dot x}\dot\xi) d\tau=
L_{\dot x}\xi\Big|_{t_1}^{t_2}+\int_{t_1}^{t_2}\Big(L_x-\frac{d L_{\dot x}}{dt}\Big)\xi d\tau$$
Take a look at Greenwood's equations (4-51), (4-52), (4-53). Still nonsense?
Substituting ##~\delta \mathbf{r}=s\cdot\mathbf{\xi}(t)~## is just doing the same thing with a different notation (Greenwood's (4-46) ).
Sure. Because a definition of ##\delta\boldsymbol {\dot r}_i## is missing.
Ah okay, so basically Lagranges Equations originally come from d'alemberts Principle and not from the Hamilton Principle, the Hamilton Principle is only a consequence of Lagranges Interpretation of Mechanics? Have I understood that right, therefore the Hamilton Principle is always just given without any explenation of its mathematical derivation.
I refreshed my memory using Goldstein's book. I'll consider only one generalized coordinate ##q## compatible with the constraints. The generalization to any number of GC is straightforward. Start from Newton's second law in Cartesian coordinates$$\mathbf{F}_i-\dot{\mathbf{p}}_i=0\quad.$$Noting that no virtual work is done by the constraint forces when the virtual displacement is ##\delta q## , one gets d'Alembert principle$$\delta K:=\left[\frac{d}{dt}\left(\frac{\partial L}{\partial \dot{q}}\right)-\frac{\partial L}{\partial q}\right]~\delta q=0\quad.$$Now you can see that mathematically$$\delta\int_{t_1}^{t_2}L(q,\dot{q},t)~dt= \int_{t_1}^{t_2}\delta K~dt +\left[\frac{\partial L}{\partial \dot{q}} \delta q\right]_{t_1}^{t_2}$$where the equal time distance ##~\delta q(t)~## to the virtually varied path is the same on both sides of the equation. So to guarantee ("derive") ##~\delta\int L~dt=0~## , you must impose the endpoints condition. Once you've done that, Hamilton's principle is equivalent to Newton's law or d'Alembert principle, and can replace them as the starting point. It contains all the physical content they do (which is basically what @wrobel wrote in #13).
But Hamilton's principle can also be used to derive the generalization of Euler-Lagrange equations for non-mechanical systems (such as fields, for example). Newton's law can't go that far.
Remember that Physics is an empirical science. We can't derive everything. Newton has postulated his second law because experiments/observations suggested it.
Thanks for your explanation I have finally understood it now :)
  • · Replies 25 ·
  • · Replies 17 ·
12K
