Derivation of the shape of a clepsydra
  • Thread starter Thread starter jakncoke
    Derivation Shape
The discussion focuses on deriving the shape of a clepsydra, a historical water clock, under the condition that the water level decreases at a constant rate. The key principle involved is Torricelli's Law, which relates the speed of fluid flowing out of an orifice to the height of the fluid above it. The solution requires establishing a relationship between the volume of water and the height, leading to a constant rate of change in height over time. The problem can be approached through the Calculus of Variations, although a simpler geometric shape may suffice for practical purposes.
  • Understanding of Torricelli's Law
  • Familiarity with Calculus of Variations
  • Knowledge of volume of revolution concepts
  • Basic principles of fluid dynamics
  • Explore the applications of Torricelli's Law in fluid mechanics
  • Study the principles of Calculus of Variations in optimization problems
  • Investigate geometric shapes suitable for modeling fluid flow
  • Learn about the mathematical modeling of water clocks and their historical significance
Students of physics and mathematics, particularly those studying fluid dynamics and optimization problems, as well as educators looking for practical applications of calculus concepts.
jakncoke
Clepsydra was a water clock used in old times in which water was allowed to espace through a small hole at the bottom. Find the shape of the clepsydra, if the water level is to fall at a constant rate.
Torricelli Law
No clue.
The point is that water falls at a constant rate- that is, the volume of water is reducing at a constant rate dV/dt. If you know the shape of the curve forming the walls (I would assume a volume of rotation), you can find V as a function of h, then you can find dV/dt as a function of dh/dt and find the function so that dh/dt is also constant. In its full generality, this is a "Calculus of Variations" problem but you are probably expected to guess a simple shape and then show it is correct.
  • · Replies 20 ·
  • · Replies 42 ·
