Torricelli's Law With Water Drawn In
8 replies · 4K views
Yohanna
An open cylinder of height 5ft and cross sectional area of 1 ft2 is initially empty. There is a small hole at the bottom of the cylinder with an area of 0.005 ft2. Water is drawn into the tank at a rate of 4.8ft3/min. At the same time water is discharged out of the cylinder through a small hole at the bottom of the tank. The outlet velocity may be estimated from Torricelli’s theorem. Estimate the time required for the water level in the tank to reach one foot depth.
dVolume/dTime = -a(2gy)^(1/2)
I tried to solve this by Torricelli's Law and setting up a model that :
Volume of water remain in tank = Volume water in-volume water out
But I found that time need for water level in tank = 1 foot is only 0.21 second
I think the model is wrong, please help me with the model.
You'll need to show your work in more detail than that.
Of course, if there was no hole, it would take less time to fill. So how long would it take if there was no hole?
(You can use that time to check if your answer is reasonable.)
Thank you for your hint.
I calculate the time to reach height of 1 foot is 12.5 second if there is no hole, then if there is a hole, it will takes longer time to reach that height. It proof my answer 0.21 second is wrong.
here is my detailed calculation :
cross sectional area of 1 ft2 = B
area of hole 0.005 ft2 = A
velocity in = 4.8 ft^3/min
velocity out = squareroot of 2gh
model :
equation :
B (delta h) = 4.8(delta t) - A (squareroot of 2gh) (delta t)
B (delta h) = [4.8- A (squareroot of 2gh)] (delta t)
(1) (delta h) = [4.8 - 0.04 {squareroot (h)}] (delta t)
dh = [4.8 - 0.04 {squareroot (h)}] dt
Integration of both sides :
h = [4.8 - 0.04 {squareroot (h)}] t
To reach h = 1 :
1 = [4.8 - 0.04 {squareroot(1)}] t
1 = 4.76 t
t = 0.21 second
I think I see three mistakes. A big one is that you didn't convert 4.8 ft3/minute into ft3/second! That's why your answer was off by so much. Also you seem to be saying [itex]A\sqrt{2g}=0.04[/itex] which is not correct.
But there is also an important mistake with your integration; you integrated h with respect to dt as if h were a constant, but h is not constant over time so you're not allowed to do integrate like you did. The correct integral is not as nice :(
Thank you for your inspiration again :) , yup i made mistakes and tried to redo it again.
I recalculate as :
g = 32.17 ft/sec2
velocity in = 4.8 ft3/min = 0.08 ft3/sec
velocity out = α√2gh ; α = 0.6 (source : J.C Borda, based on Edwin Kreyzig's Book) = (0.6) √(2)(32.17)h = 4.812 √h
Δh = (ϑin Δt)/B - (ϑout Δt A)/B
Δh = {0.08 - (0.005) (4.812 √h) } Δt / B
Δh = {0.08 - (0.005) (4.812 √h) } Δt / 1
Δh = {0.08 - (0.005) (4.812 √h) } ΔtAfter this, what should I do next to get the equation of depth of the water in the tank at any time ?
Firstly, sorry for saying your 0.04 was wrong; I'm used to using units of meters (where g is 9.8) so I got that mixed up.
You have the equation [itex]dh=\big(0.08-A\sqrt{2gh}\big)dt[/itex]
You can integrate both sides like you tried in post #3, but you need to keep the h with the dh. So the integral becomes [itex]\int\limits_0^1 \frac{dh}{0.08-A\sqrt{2gh}}=\int\limits_0^T dt[/itex]
(T is the time you wish to solve for)
As for calculating the integral... I don't immediately see how to do it. I may not be able to help you with that part.
This is also give me inspiration how to do this, of course don't need to be sorry for telling my mistake, thank you for that, I really mean it.
Now I just need to solve the integral, I am close to see the answer. I will post again here once I get it, thank you so much !
Here is the full answer, as I said before..
Water level in the tank is x at limit time t.
Amount of water in = 4.8 ft3/min
amount of water out = (vout) (A hole) = (vout) (0.005) = 0.04 x0.5
v out= sqrt (2gh) = sqrt(2gx) = sqrt [(2)(32.2 ft/sec2)(x)]
Then we setting up the model as :
amount of water in - amount of water out = rate of accumulation
(4.8/60) ft3/sec - v Ahole = d/dt (Atank x)
0.08 - 0.04x0.5 = d/dt [(1)(x)]
dx/dt = 0.08-0.04x0.5
This equation can be separated as :
dx/(0.08-0.04x0.5) = dt
dx/ (2-x0.5) = 1/25 dt ...(1)
To solve this, let's assume :
z=2-x0.5
-x0.5=z-2
dz/dx=-0.5 (1/x0.5)
dx = -2x0.5dz
subtitute to equation (1), then we have :
-2x0.5dz /z=0.04 dt
2(z-2) dz/z=0.04 dt
Integrating both sides :
2z-4lnz = 0.04t+c
2(2-x0.5)- 4ln(2-x0.5)=0.04t+c General Solution
Subtitute initial condition x(0) = 0, then we have c=4(1-ln2)
2(2-x0.5)- 4ln(2-x0.5)=0.04t+ 4 (1-ln2) Particular solution
x = 1 ft
Subtitute x=1 ft to particular solution, then we have t=19.3 sec
Did you account for volume pressure/suction at the hole or is that not relevant?
