Derivation of Wheel Relationship Formulas
5 replies · 2K views · last reply
bagasme
Hello,
Here in this thread I will derive formulas for relation between two wheels, either teethed (e.g. gears) or non-teethed.
In wheel relationship, we have three cases:
  1. Two wheels at the same axle
  2. Two wheels intersected in parallel (meshed)
  3. Two wheels connected by a belt
We will examine each cases above on smooth (non-teethed) wheels first.
1. At the same axle
Diagram of two concentric black circles with dashed red arrows showing rotation in the same direction, labelled ω_A for the inner circle and ω_B for the outer circle.
Figure 1 (source: fisikabc.com) shows two wheels connected to the same axle. Since both ##A## and ##B## are on same center, they have same angular accelleration:
$$\begin{align}
\omega_A & = \omega_B \nonumber \\
\frac {v_A} {r_A} & = \frac {v_B} {r_B} ~ (1)\nonumber
\end{align}$$
2. Intersected in Parallel
Diagram of two black-rimmed wheels meshing side by side on a lavender background; the smaller left wheel and larger right wheel touch, with a yellow vertical arrow labelled VA and VB at the contact point, red dashed arcs showing rotation, and labels ωA and ωB.
Figure 2 (source: fisikabc.com) show two wheels intersected each other in parallel. When wheel ##A## rotated counter-clockwise, wheel ##B## rotated clockwise, and vice versa. At the intersection point between two wheels, linear velocity of both wheels directed at the same direction, so:
$$\begin{align}
v_A & = v_B \nonumber \\
\omega_A \cdot r_A &= \omega_B \cdot r_B ~ (2)\nonumber
\end{align}$$
3. Connected by Belt
Diagram of two smooth wheels connected by a dashed belt, with the top belt segment moving right; the left wheel has velocity v_A and angular velocity ω_A, the right wheel has velocity v_B and angular velocity ω_B, and curved red dashed arrows show their rotation directions.
Figure 3 (source: fisikabc.com) shows two wheels connected by a belt. As wheel ##B## rotated, the belt rotated wheel ##A## at the same linear velocity direction as wheel ##B##. Thus the formula is same as when both wheels intersected directly (2).
Relationship Involving Teethed Wheels (e.g. Gears)
We will now deriving equations that relate between angular velocity, radius, and number of teeth. ##N_A## and ##N_B## are number of teeth of wheel A and B, respectively.
From equation (2):
$$\begin{align}
\omega_A \cdot r_A & = \omega_B \cdot r_B \nonumber \\
\frac {2 \cdot \pi \cdot r_A} {t} & = \frac {2 \cdot \pi \cdot r_B} {t} \nonumber \\
r_A &= r_B \nonumber \\
\frac {r_A} {n_A} &= \frac {r_B} {n_B} \nonumber \\
r_A \cdot N_B &= r_B \cdot N_A \nonumber \\
\frac {r_A} {r_B} &= \frac {N_A} {N_B} ~ (3) \nonumber
\end{align}$$
Combining equation (2) and (3):
$$\begin{align}
\frac {\omega_A} {\omega_B} &= \frac {r_B} {r_A} \nonumber \\
\frac {\omega_A} {\omega_B} &= \frac {N_B} {N_A} \nonumber \\
\end{align}$$
We can conclude that angular accelleration is related to radius, but inverse related to number of teeth.
I hope that this thread will be useful. Please let me know any flaws and suggestions.
Cheers, Bagas
When you say ##\dfrac{2\pi r_A}{t}=\dfrac{2\pi r_B}{t}##, you are assuming that the two geared wheels have the same radius. This means that ##N_A=N_B## and ##\omega_A=\omega_B##. Not an interesting case. What you want to say is that the number of teeth per unit length in A must be the same as in B otherwise the teeth will not mesh.
bagasme said:
... Figure 1 (source: fisikabc.com) shows two wheels connected to the same axle. Since both ##A## and ##B## are on same center, they have same angular acceleration velocity:
We can conclude that angular accelleration velocity is related to radius, but inverse related to number of teeth.
Thank you, Bagas.
I believe you meant angular velocity in both cases.
What I mean was cancelling ##\frac {2\pi} {t}## from both sides, so ##r_A## is not necessarily same as ##r_B##.
Since I can't edit my first post here, let me update derivation of (3).
From equation (2), we divide each sides by number of teeth of each wheels:
$$\begin{align}
\omega_A \cdot r_A &= \omega_B \cdot r_B \nonumber \\
\frac {\omega_A \cdot r_A} {N_A} &= \frac {\omega_B \cdot r_B} {N_B} \nonumber \\
\dfrac {\dfrac {2 \cdot \pi \cdot r_A} {t}} {N_A} &= \dfrac {\dfrac {2 \cdot \pi \cdot r_B} {t}} {N_B} \nonumber \\
\frac {r_A} {N_A} &= \frac {r_B} {n_B} ~(\text {cancel} ~ \dfrac {2 \cdot \pi} {t} ~ \text {on both sides}) \nonumber \\
\frac {r_A} {r_B} &= \frac {N_A} {N_B} ~ (3) \nonumber \\
\end{align}$$
$$\begin{align}
\end{align}$$
Not better. Look at the second equation. You get it from the first by dividing the left side by ##N_A## and the right side by ##N_B##. That's OK as long as ##N_A=N_B## which means that equation (3) says ##\dfrac{r_A}{r_B}=1##. You have all the pieces but you are not sure how to put them together and you are going around in circles. You did not pay attention to what I suggested in post #2: What you want to say is that the number of teeth per unit length in A must be the same as in B otherwise the teeth will not mesh. Start from there.
  • Wow
