Derivation of Wheel Relationship Formulas
This discussion focuses on deriving formulas for the relationships between two wheels, specifically in three scenarios: wheels on the same axle, intersected in parallel, and connected by a belt. The key equations derived include the relationships for angular velocity and radius, particularly emphasizing that angular acceleration is inversely related to the number of teeth in teethed wheels. The final formula established is r_A / r_B = N_A / N_B, illustrating the direct correlation between radius and the number of teeth for gears.
  • Understanding of angular velocity and acceleration
  • Familiarity with basic mechanics of gears and wheels
  • Knowledge of mathematical derivation and manipulation of equations
  • Concept of linear velocity in rotational systems
  • Study the principles of gear ratios and their applications in mechanical systems
  • Learn about the dynamics of belt-driven systems and their efficiency
  • Explore advanced topics in rotational kinematics and dynamics
  • Investigate the impact of friction and material properties on gear performance
Mechanical engineers, physics students, and anyone involved in designing or analyzing gear systems and mechanical linkages.
bagasme
Hello,
Here in this thread I will derive formulas for relation between two wheels, either teethed (e.g. gears) or non-teethed.
In wheel relationship, we have three cases:
  1. Two wheels at the same axle
  2. Two wheels intersected in parallel (meshed)
  3. Two wheels connected by a belt
We will examine each cases above on smooth (non-teethed) wheels first.
1. At the same axle
Figure 1 (source: fisikabc.com) shows two wheels connected to the same axle. Since both ##A## and ##B## are on same center, they have same angular accelleration:
$$\begin{align}
\omega_A & = \omega_B \nonumber \\
\frac {v_A} {r_A} & = \frac {v_B} {r_B} ~ (1)\nonumber
\end{align}$$
2. Intersected in Parallel
Figure 2 (source: fisikabc.com) show two wheels intersected each other in parallel. When wheel ##A## rotated counter-clockwise, wheel ##B## rotated clockwise, and vice versa. At the intersection point between two wheels, linear velocity of both wheels directed at the same direction, so:
$$\begin{align}
v_A & = v_B \nonumber \\
\omega_A \cdot r_A &= \omega_B \cdot r_B ~ (2)\nonumber
\end{align}$$
3. Connected by Belt
Figure 3 (source: fisikabc.com) shows two wheels connected by a belt. As wheel ##B## rotated, the belt rotated wheel ##A## at the same linear velocity direction as wheel ##B##. Thus the formula is same as when both wheels intersected directly (2).
Relationship Involving Teethed Wheels (e.g. Gears)
We will now deriving equations that relate between angular velocity, radius, and number of teeth. ##N_A## and ##N_B## are number of teeth of wheel A and B, respectively.
From equation (2):
$$\begin{align}
\omega_A \cdot r_A & = \omega_B \cdot r_B \nonumber \\
\frac {2 \cdot \pi \cdot r_A} {t} & = \frac {2 \cdot \pi \cdot r_B} {t} \nonumber \\
r_A &= r_B \nonumber \\
\frac {r_A} {n_A} &= \frac {r_B} {n_B} \nonumber \\
r_A \cdot N_B &= r_B \cdot N_A \nonumber \\
\frac {r_A} {r_B} &= \frac {N_A} {N_B} ~ (3) \nonumber
\end{align}$$
Combining equation (2) and (3):
$$\begin{align}
\frac {\omega_A} {\omega_B} &= \frac {r_B} {r_A} \nonumber \\
\frac {\omega_A} {\omega_B} &= \frac {N_B} {N_A} \nonumber \\
\end{align}$$
We can conclude that angular accelleration is related to radius, but inverse related to number of teeth.
I hope that this thread will be useful. Please let me know any flaws and suggestions.
Cheers, Bagas
When you say ##\dfrac{2\pi r_A}{t}=\dfrac{2\pi r_B}{t}##, you are assuming that the two geared wheels have the same radius. This means that ##N_A=N_B## and ##\omega_A=\omega_B##. Not an interesting case. What you want to say is that the number of teeth per unit length in A must be the same as in B otherwise the teeth will not mesh.
bagasme said:
... Figure 1 (source: fisikabc.com) shows two wheels connected to the same axle. Since both ##A## and ##B## are on same center, they have same angular acceleration velocity:
We can conclude that angular accelleration velocity is related to radius, but inverse related to number of teeth.
Thank you, Bagas.
I believe you meant angular velocity in both cases.
What I mean was cancelling ##\frac {2\pi} {t}## from both sides, so ##r_A## is not necessarily same as ##r_B##.
Since I can't edit my first post here, let me update derivation of (3).
From equation (2), we divide each sides by number of teeth of each wheels:
$$\begin{align}
\omega_A \cdot r_A &= \omega_B \cdot r_B \nonumber \\
\frac {\omega_A \cdot r_A} {N_A} &= \frac {\omega_B \cdot r_B} {N_B} \nonumber \\
\dfrac {\dfrac {2 \cdot \pi \cdot r_A} {t}} {N_A} &= \dfrac {\dfrac {2 \cdot \pi \cdot r_B} {t}} {N_B} \nonumber \\
\frac {r_A} {N_A} &= \frac {r_B} {n_B} ~(\text {cancel} ~ \dfrac {2 \cdot \pi} {t} ~ \text {on both sides}) \nonumber \\
\frac {r_A} {r_B} &= \frac {N_A} {N_B} ~ (3) \nonumber \\
\end{align}$$
$$\begin{align}
\end{align}$$
Not better. Look at the second equation. You get it from the first by dividing the left side by ##N_A## and the right side by ##N_B##. That's OK as long as ##N_A=N_B## which means that equation (3) says ##\dfrac{r_A}{r_B}=1##. You have all the pieces but you are not sure how to put them together and you are going around in circles. You did not pay attention to what I suggested in post #2: What you want to say is that the number of teeth per unit length in A must be the same as in B otherwise the teeth will not mesh. Start from there.
  • Wow
  • · Replies 21 ·
9K
