Derivative of a Noether current from Dirac Equation
The discussion centers on deriving the divergence of the Noether current from the Dirac equation under U(1) transformations. The Noether current is expressed as \( J^{\mu} = -\bar{\psi}\gamma^{\mu}\gamma^{5}\psi \). The divergence is calculated as \( \partial_{\mu}J^{\mu} = -(\partial_{\mu}\bar{\psi}\gamma^{\mu}\gamma^{5}\psi + \bar{\psi}\gamma^{\mu}\gamma^{5}\partial_{\mu}\psi) \). Participants emphasize the importance of using the original equations of motion from the untransformed Lagrangian, as the transformation does not yield a symmetry unless the mass \( m = 0 \).
  • Understanding of U(1) transformations in quantum field theory
  • Familiarity with the Dirac equation and gamma matrices
  • Knowledge of Noether's theorem and its application to conserved currents
  • Ability to manipulate Lagrangians and derive equations of motion
  • Study the implications of Noether's theorem in quantum field theory
  • Learn about the properties and applications of gamma matrices in particle physics
  • Explore the significance of symmetry breaking in quantum field theories
  • Investigate the role of mass terms in Lagrangians and their effects on symmetries
Physicists, particularly those specializing in quantum field theory, theoretical physicists working on particle physics, and students studying advanced topics in quantum mechanics.
Dixanadu
Hey guys,
Consider the U(1) transformations
\psi'=e^{i\alpha\gamma^{5}}\psi and \bar{\psi}'=\bar{\psi}e^{i\alpha\gamma^{5}} of the Lagrangian \mathcal{L}=\bar{\psi}(i\partial_{\mu}\gamma^{\mu}-m)\psi.
I am meant to find the expression for \partial_{\mu}J^{\mu}.
Gamma matrices anticommute
Noether current is \delta J^{\mu}=\frac{\partial\mathcal{L}}{\partial(\partial_{\mu}\psi)}\delta\psi+\delta x \mathcal{L}
not sure of anything else...
So here's what I've done so far. Since its a U(1) transformation, the coordinates arent changing, so the Noether current is given by \delta J^{\mu}=\frac{\partial\mathcal{L}}{\partial(\partial_{\mu}\psi)}\delta\psi. I found that \delta\psi=i\alpha\gamma^{5}\psi, so that
\delta J^{\mu}=-\bar{\psi}\alpha\gamma^{\mu}\gamma^{5}\psi, then I drop the infinitesimal parameter to get
J^{\mu}=-\bar{\psi}\gamma^{\mu}\gamma^{5}\psi.
So the next step is to calculate the derivative of this. Doing so, I get
\partial_{\mu}J^{\mu}=-(\partial_{\mu}\bar{\psi}\gamma^{\mu}\gamma^{5}\psi+\bar{\psi}\gamma^{\mu}\gamma^{5}\partial_{\mu}\psi)
And at this point I am stuck...im not sure if this is right and/or if I can simplify this or do something neat with it? because I think I'm meant to be using the transformed Lagrangian
\mathcal{L}'=i\bar{\psi}\partial_{\mu}\gamma^{\mu}\psi-m\bar{\psi}e^{2i\alpha\gamma^{5}}\psi
for something but I don't really know.
Thanks guys..
What equations of motion do you have?
I think its just the equations of motion from the untransformed Lagrangian, which are:
(i\partial_{\mu}\gamma^{\mu}-m)\psi=0
and
i(\partial_{\mu}\bar{\psi})\gamma^{\mu}+m\bar{\psi}=0
So I suggest using those. :)
I thought of that but I'm not sure if I can use these because I'm considering the transformed Lagrangian...and the above transformations arent a symmetry unless m = 0. So how can I use these equations of motion?
The fields will follow their equations of motion. Had the transformation of the fields been a symmetry of the Lagrangian, the divergence of the current would be zero. Since it is not, you will simply get a non-zero expression if you anyway chose to write down the current that would be conserved if the symmetry breaking parameter was zero.
I see...so I guess I am doing it wrong? I mean I've found the equations of motion from the transformed Lagrangian
(i\partial_{\mu}\gamma^{\mu}- m e^{2i\alpha\gamma^{5}})\psi=0
and
i \partial_{\mu}\bar{\psi}\gamma^{\mu}+m\bar{\psi}e^{2i\alpha\gamma^{5}}=0
and now I'm trying to use THESE inside my expression for \partial_{\mu}J^{\mu}. I guess you're saying to just use the orignals I posted in post #3?
I get a nonzero answer either way but I'm not sure which one is right...:(
and
Yes, this willbe the divergence of the current.
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 25 ·
