Derivative of f(x) to the power of g(x), and algebra problem
The discussion focuses on deriving the derivative of the function h(x) = [f(x)]^{g(x)} and solving for constants A and B in the equation A/x + B/(P-x) = 1/(x(P-x)). The correct derivative is established as h'(x) = [f(x)]^{g(x)}(g'(x)ln[f(x)] + g(x)f'(x)/f(x)). For the second problem, the values are determined as A = 1/P and B = 1/P through coefficient comparison after simplifying the equation.
  • Understanding of derivatives and the chain rule in calculus
  • Familiarity with logarithmic differentiation
  • Knowledge of algebraic manipulation and solving equations
  • Basic concepts of real functions and their properties
  • Study the application of logarithmic differentiation in complex functions
  • Learn about the chain rule and its implications in calculus
  • Explore methods for solving rational equations and finding coefficients
  • Practice deriving functions involving variable exponents and logarithms
Students studying calculus, mathematicians working on function derivatives, and anyone interested in algebraic problem-solving techniques.
Deadleg
1. If f(x), g(x) and h(x) are real functions of x, show that
when h(x)=[f(x)]^{g(x)}
then h'(x)=[f(x)]^{g(x)}(g'(x)\ln[f(x)]+g(x)\frac{f'(x)}{f(x)})
2. \frac{A}{x}+\frac{B}{P-x}=\frac{1}{x(P-x)} where x is a variable, and P is a constant. Find A and B in terms of P.
1. I start by doing what I usually do, like with x^{x^2}:
[f(x)]^{g(x)-1}.g(x).g'(x)
Looking at the derivative, I see
\int{g'(x)\ln[f(x)]+g(x)\frac{f'(x)}{f(x)}}=g(x)\ln[f(x)]
Which looks nothing like what I got :(
2. Getting a common denominator and canceling:
A(P-x)+Bx=1
Then by inspection,
A=\frac{P}{P^2}
B=\frac{1}{P^2}
It was a fluke that I got that :/. So I'm wondering how to prove it arithmetically, or just some general method of solving these kinds of problems for when I come across them again.
Hi Deadleg,
If we can get your example x^{x^2} sorted then you will be fine to do the question at hand. We rewrite it as x^{x^2} = e^{x^2\log{x}, and then differentiate (using the chain rule), obtaining (2x\log{x} + x})e^{x^2\log{x}, i.e., (2x\log{x} + x})x^{x^2}.
The exact same technique applies to your problem.
A(P-x)+Bx=1
Then by inspection,
A=\frac{P}{P^2}
B=\frac{1}{P^2}
Actually, you're not quite right (did you test your inspection?). From your (correct) equation A(P-x)+Bx=1, we can then gather like terms: x(-A + B) + AP = 1, and then equate coefficients (of powers of x).
You can't treat (f(x))^(g(x)) like it was a power function like x^n. f(x)^g(x)=e^(log(f(x)*g(x)). Use the chain rule on that. For the second one, you've got 1=AP-Ax+Bx=AP+(B-A)x. Since those are supposed to be equal for ALL values of x, you must have AP=1 since that's the constant the right side, and (B-A)=0 since there is no x on the right side. And I don't think you got it right.
Ah, so for 1.
h(x)=[f(x)]^{g(x)}=e^{g(x)\ln[f(x)]}
h'(x)=e^{g(x)\ln[f(x)]}.(g'(x)\ln[f(x)]+g(x)\frac{f'(x)}{f(x)})
h'(x)=[f(x)]^{g(x)}.(g'(x)\ln[f(x)]+g(x)\frac{f'(x)}{f(x)})
And for 2.
A(P-x)+Bx=1
AP+(B-A)x=1
AP=1,\ A=\frac{1}{P}
B-A=0,\ B=A=\frac{1}{P}
That's it exactly.
