Is the Derivative of (1+1/x)^x Always Positive?
  • Thread starter Thread starter haiha
    Derivative
The discussion centers on proving that the derivative of the function y=(1+1/x)^x is always positive. Participants analyze the derivative, y' = (1+1/x)^x [ln(1+1/x) - 1/(x+1)], and debate the importance of domain constraints, noting that the function is undefined at x=0. They conclude that for x > 0, the derivative is positive due to the behavior of its components, while also acknowledging that the function's behavior for x < -1 complicates the assertion of positivity. Ultimately, the consensus is that the derivative is not universally positive across all real numbers, especially considering the function's domain.
haiha
How can can prove that the derivative of y=(1+1/x)^x is always positive?
Thank you
Mathematics news on Phys.org
y=(1+1/x)^x
Let u=1+1/x,y=u^x
y=u^x
ln y=x ln u
y'/y=x/u
dy/du=[x/(1+1/x)](1+1/x)^x
=x(1+1/x)^(x-1)
du/dx=-1/x^2
dy/dx=(dy/du)(du/dx)
=x(1+1/x)^(x-1) (-1/x^2)
=-(1+1/x)^(x-1) /x
y=(1+1/x)^x
Let u=1+1/x,y=u^x
y=u^x
ln y=x ln u
Then how come y'/y=x/u ?
I think the derivative of y will be calculated as follow:
y'/y=(x ln u)' = x*(1/u)u' + ln u (derivative of a product)
==> y' = y[x/(1+1/x)* (-1/x^2) +ln (1+1/x)]
y' = y [ln(1+1/x)-1/(x+1)]
y' = (1+1/x)^x [ln(1+1/x)-1/(x+1)]
The problem here is that I can not prove y' always positive
Your derivative is correct. Now, you should look at the domain and image of this function.
Thank you
it's not. at x = 0 it's undefined, for instance
Yes, I should avoid the value x=0. Except from that, let say, for all x >0, why the derivative is always positive?
So? Graph the function and it will be pretty obvious that y'(x) > 0, for every x from (0, +\infty).
radou said:
So?
because the question asked about the function without any constraints on x's domain.
part of the problem people have while tackling questions like this is they don't emphasise the domain, as you pointed out yourself
also a graph may make it "pretty obvious", but this isn't a proof
Well, constraints on domains are self understood. It wouldn't make any sense to talk about values of the function on an interval where it isn't defined, would it?
depends how far into analysis you get. undefined points are crucial and interesting at some levels
Thank you all for discussing. I have graphed the curve and the derivative will leads to plus zero (+0) when x --> infinity. So in the domain of 0<x<inf, the derivative must be positive. But infact that is not a proof.
have you tried the binomial theorem?
edit: done some calculating and that doesn't seem to help. i only have pencil and paper here, lol
The domain of this function is (-\infty, -1) U (0, \infty), not just x> 0.
being really pedantic: the domain is any set you (or the questioner) chooses so long as the rule is defined on that set
a function is defined by the rule and the domain
i still haven't found a neat way to do proof though
We make it : y' = A*B
Where A= (1+1/x)^x and B=ln(1+1/x/)-1/(x+1)
Because A>0 (every x>0), so we check the state of B.
The derivative of B: B'= [ln(1+1/x)-1/(x+1)]'=...=1/(x+1)[1/(x+1)-1/x] <0 with all the values of x>0. So B is a contravariant function.
We also have the fact that when x--> inf the B leads to zero, so all the values of B in the domain x>0 must be positive.
Then y' = A*B also is positive.
Anyone noticed the limit of this function as it approaches infinity is e? Just some interesting info for you all..
Yes, and the function y=(1+a/x)^x will approaches e^a when x goes to infinity. Can you prove that?
There is no need to prove that, it is true by definition. The challenge would be to prove different definitions of e are equivalent.
It is true by one definition of e. If, for example, you define
ln(x)= \int_1^x \frac{1}{t}dt
and then define exp(x) to be the inverse function to ln(x), you would need to prove that
\lim_{x\rightarrow \infty}\left(1+ \frac{a}{x}\right)^x= exp(a)
To simplify the question, prove that (1+1/x)^x < 0 for x < 0 and x =/= 0 and x=/= -1. For x < -1, (1+1/x)^x takes a positive value. If we define ln -|x| = - ln |x|, then the derivative is negative for x < -1. It is not always positive.
