MitsuShai
- 159
- 0
For the function
f(x)=(x^2-3)/(x-2),
determine the locations of any points of inflection, if any
The discussion revolves around determining the locations of points of inflection for the function f(x)=(x^2-3)/(x-2). Participants explore the implications of the function's form and its derivatives in relation to inflection points.
The discussion is ongoing, with participants examining the definitions of critical points and inflection points. Some express confusion about the implications of x=2 being a vertical asymptote, while others assert that it cannot be an inflection point due to the function's discontinuity at that point.
There is a noted discrepancy in the function's representation, leading to confusion about its domain and the behavior of its derivatives. Participants are also navigating the constraints of an online homework system that requires specific formatting for answers.
crims0ned said:Your function is f(x)=(x^2-3)(x-2) right? Maybe if you foil it out first before you take the derivative?
crims0ned said:f(x)=(x^2-3)(x-2) is a polynomial and therefore it's domain should be all real number and this should carry on to it's derivatives as well.
f(x)=(x^2-3)(x-2) = x^3-2x^2-3x+6 right? So there shouldn't be a quotient at all.
Is there a typo in your functions? You have f(x)=(x^2-3)(x-2), but from what you have for f''(x), did you mean f(x) = (x^2 - 3)/(x -2)?MitsuShai said:Homework Statement
For the function
f(x)=(x^2-3)(x-2),
f ''(x) = (2(x−2))/(x−2)^4
ok the concavity is (2, infinity) concave up
and (-infinity, 2) concave down, I entered them in as my answer and they were right
as for the inflection point, 2 is undefined, so I assumed that the function does not have an inflection point. I typed in 0 with a slash through it/ "{}" as my answer. My professor said that represents that there is no inflection point. But I got it wrong and I don't see another inflection point on the graph...
Mark44 said:Is there a typo in your functions? You have f(x)=(x^2-3)(x-2), but from what you have for f''(x), did you mean f(x) = (x^2 - 3)/(x -2)?
crims0ned said:okay, so we have f(x)=\frac{(x^2-3)}{(x-2)} and f''(x)=\frac{2(x-2)}{(x-2)^4} Even though x=2 is a vertical asymptote it is still a critical point on the second derivative
crims0ned said:You're right it shouldn't be an inflection point because the original functions tangent line doesn't at x=2, but possibly it's asking for all critical points on the second derivative? Is this some kind of online homework program?
No, that's not true. 2(x - 2)/(x - 2)^4 is identically equal to 2/(x - 2)^3. x = 2 is not in the domain of either function, so is not a critical number for the 2nd derivative. It's true that the concavity changes on either side of x = 2 for the original function, but for x = c to be an inflection point, f has to be defined at c. IOW, I agree with you that the function has no inflection point.crims0ned said:okay, so we have f(x)=\frac{(x^2-3)}{(x-2)} and f''(x)=\frac{2(x-2)}{(x-2)^4} Even though x=2 is a vertical asymptote it is still a critical point on the second derivative
crims0ned said:Isn't the definition of a critical point a point on f(x) that occurs at x0 if and only if either f '(x0) is zero or the derivative doesn't exist at that point?
For x0 in the domain of f, x0 is a critical point if either f'(x0) = 0 or f' is not defined at xp.crims0ned said:Isn't the definition of a critical point a point on f(x) that occurs at x0 if and only if either f '(x0) is zero or the derivative doesn't exist at that point?
Mark44 said:For x0 in the domain of f, x0 is a critical point if either f'(x0) = 0 or f' is not defined at xp.
The trouble is that x = 2 is not in the domain of the original function, f(x) = (x2 - 3)/(x - 2), so couldn't possibly be an inflection point.
Mark44 said:There isn't one. The only place the concavity changes is at x = 2, but x = 2 isn't in the domain of the original function.
