Derivatives-volume of a cyclinder
  • Thread starter Thread starter roman15
The discussion centers on finding the radius of a cylinder that maximizes volume given the corrected volume formula v = 50r - πr³ and a surface area of 100 cm². Initially, the user presented an incorrect formula that resulted in negative volume values for certain radii. After clarification, the correct equation simplifies the problem significantly, allowing for straightforward application of calculus to determine the optimal radius within the specified range of 0 < r < 3.
  • Understanding of calculus, specifically optimization techniques.
  • Familiarity with the geometric properties of cylinders.
  • Knowledge of the relationship between volume and surface area.
  • Basic proficiency in algebraic manipulation of equations.
  • Study optimization techniques in calculus, focusing on critical points and the first derivative test.
  • Review the geometric formulas for volume and surface area of cylinders.
  • Practice problems involving the maximization of functions with constraints.
  • Explore the implications of negative values in volume equations and their physical significance.
Students preparing for calculus exams, educators teaching optimization problems, and anyone interested in the mathematical properties of geometric shapes.
roman15
im just reviewing for a test tomorrow and I am stuck on this question, any help is appreciated
if the volume of a cylinder is v=50-3pir^3, the surface area is 100cm^2 and the range of the radius is 0<r<3, what is the radius that will give the maximal volume?
I don't think you're giving us all the information. Can we assume that this is a circular cylinder? And that formula for the volume is very unusual - it gives negative values for volume when r is greater than about 1.744 cm.
Are you sure you have given us the exact information of this problem?
im so sorry, i was using the wrong equation for the volume, is should be v=50r-pir^3, now the question is really easy but thanks for taking your time to help
  • · Replies 33 ·
  • · Replies 20 ·
