Deriving Helmholtz Thermodynamic Potential & Corresponding Maxwell Relation
2 replies · 6K views
Hart
To state the differential form of the Helmholtz thermodynamic potential and
derive the corresponding Maxwell's relation.
Stated within the solution attempt.
  • Helmholtz function: [tex]F = U - TS[/tex]
  • Calculating the differential form:
    For infinitesimal change: [tex]dF = dU - tdS - SdT[/tex]
    Then using: [tex]TdS = dU + PdV[/tex] ,
    Therefore:
    [tex]dF = -PdV - SdT[/tex]
  • Which then follows that can write: [tex]F = F(V,T)[/tex]
    Hence:
    [tex]dF = \left(\frac{\partial F}{\partial V}\right)_{T}dV + \left(\frac{\partial F}{\partial T}\right)_{V}dT[/tex]
  • Comparing coefficients in the previous two stated expressions for [tex]dF[/tex]:
    [tex]P = -\left(\frac{\partial F}{\partial V}\right)_{T}[/tex]
    and
    [tex]S = -\left(\frac{\partial F}{\partial T}\right)_{V}[/tex]
  • Then as F is a function of state, then dF is an exact differential and
    the condition for an exact differential gives:
    [tex]\left(\frac{\partial P}{\partial T}\right)_{v} = \left(\frac{\partial S}{\partial V}\right)_{T}[/tex]
    Which is the Maxwell relation, derived as required.
Brill.. :biggrin: .. just wanted to check it through with someone else!
