Deriving Triangle Inequality: Formal Definition of Absolute Value Method
  • Thread starter Thread starter Taylor_1989
    Inequality
The discussion centers on the derivation of the triangle inequality using the formal definition of absolute value. The initial attempt incorrectly applied inequality subtraction, leading to an erroneous conclusion. After feedback, the user corrected their approach by proving that |a| - |b| ≤ |a - b|, utilizing the triangle inequality effectively. This revised method aligns with established mathematical principles and demonstrates a clear understanding of absolute value properties.
  • Understanding of absolute value definitions and properties
  • Familiarity with inequalities and their manipulation
  • Knowledge of the triangle inequality theorem
  • Basic algebraic manipulation skills
  • Study the formal definition of absolute value in depth
  • Learn about the properties and applications of inequalities
  • Explore different proofs of the triangle inequality
  • Practice problems involving absolute values and inequalities
Students studying mathematics, particularly those focusing on algebra and analysis, as well as educators looking for examples of teaching the triangle inequality and absolute value concepts.
Taylor_1989
Hi guys, I would just like someone to go over my method for this derivation/proof ( not sure of the right word to use here). Anyway I think this is right method, but just feel like I am missing something. Could someone please check my method. Thanks in advance.
$$|x|= x\geq 0 , -x < 0 $$
$$|a-b|\leq|a|-|b|$$
By using the formal definition of the absolute value I get this:
[/B]
1.$$-|a|\leq a\leq |a|$$
2.$$-|b|\leq b\leq |b|$$
1-2: $$-(|a|-|b|)\leq a-b \leq |a|-|b| $$
Therefore I get: $$|a-b|\leq|a|-|b|$$
Is this correct? Is there any improvements that anyone could share. I do have a couple more variations of the triangle inequality to go through but want to try the first before posting.
This is incorrect. Look at the case ##a=1, b=2##, or better still, the case ##a=1, b=-2##.
The first line under "relevant equations" looks odd and the second one is wrong.
You cannot subtract inequalities like that. As an example, 4<5 and 3<7, but 4-3 < 5-7 is wrong.
I wish the section for the problem statement were filled out explicitly.
@mfb and @Ray Vickson have already pointed out your mistakes. I just want to add a bit to mfb's reply.
Inequalities with same "symbol" can be added and inequalities with "different symbol" can be subtracted from one another and not the other way around.
Like ## 13 < 42## and ## -42 < -1 ## can be added to produce ##-29 < 41## and ## 42 > 13 ## and ## -42 < -1 ## can be subtracted to produce ##84 > 14##.
When subtracting the symbol of inequality from which the other is subtracted will be the symbol of the resultant inequality.
You can make an addition out of the subtraction:
##-42 < -1## is equivalent to (edit: fixed) ##42 > 1## (reverse the sign on both sides, reverse the direction of the inequality), and that can be added to ##42>13## to ##84>14##.
And if you don't like the first step, split it in substeps:
##a<b##
subtract a on both sides
##0 < b-a##
subtract b on both sides
##-b < -a##
Now write it in the other direction:
## -a > -b##.
First thanks for the response and I see the error I made. I have also notice that I put the inequity the wrong way round sorry. So I have had another attempt at the solution which is below:
Prove: $$|a|-|b|\leq|a-b|$$
Attempt:$$a=a-b+b$$
$$|a|=|a-b+b|$$
Using triangle inequity
$$|a|\leq|a-b|+|b|$$
Attempt:$$a=a-b+b$$
$$|a|=|a-b+b|$$
Looks good.
