Deriving Triangle Inequality: Formal Definition of Absolute Value Method
  • Thread starter Thread starter Taylor_1989
    Inequality
7 replies · 2K views
Taylor_1989
Hi guys, I would just like someone to go over my method for this derivation/proof ( not sure of the right word to use here). Anyway I think this is right method, but just feel like I am missing something. Could someone please check my method. Thanks in advance.
$$|x|= x\geq 0 , -x < 0 $$
$$|a-b|\leq|a|-|b|$$
By using the formal definition of the absolute value I get this:
[/B]
1.$$-|a|\leq a\leq |a|$$
2.$$-|b|\leq b\leq |b|$$
1-2: $$-(|a|-|b|)\leq a-b \leq |a|-|b| $$
Therefore I get: $$|a-b|\leq|a|-|b|$$
Is this correct? Is there any improvements that anyone could share. I do have a couple more variations of the triangle inequality to go through but want to try the first before posting.
This is incorrect. Look at the case ##a=1, b=2##, or better still, the case ##a=1, b=-2##.
The first line under "relevant equations" looks odd and the second one is wrong.
You cannot subtract inequalities like that. As an example, 4<5 and 3<7, but 4-3 < 5-7 is wrong.
I wish the section for the problem statement were filled out explicitly.
@mfb and @Ray Vickson have already pointed out your mistakes. I just want to add a bit to mfb's reply.
Inequalities with same "symbol" can be added and inequalities with "different symbol" can be subtracted from one another and not the other way around.
Like ## 13 < 42## and ## -42 < -1 ## can be added to produce ##-29 < 41## and ## 42 > 13 ## and ## -42 < -1 ## can be subtracted to produce ##84 > 14##.
When subtracting the symbol of inequality from which the other is subtracted will be the symbol of the resultant inequality.
You can make an addition out of the subtraction:
##-42 < -1## is equivalent to (edit: fixed) ##42 > 1## (reverse the sign on both sides, reverse the direction of the inequality), and that can be added to ##42>13## to ##84>14##.
And if you don't like the first step, split it in substeps:
##a<b##
subtract a on both sides
##0 < b-a##
subtract b on both sides
##-b < -a##
Now write it in the other direction:
## -a > -b##.
First thanks for the response and I see the error I made. I have also notice that I put the inequity the wrong way round sorry. So I have had another attempt at the solution which is below:
Prove: $$|a|-|b|\leq|a-b|$$
Attempt:$$a=a-b+b$$
$$|a|=|a-b+b|$$
Using triangle inequity
$$|a|\leq|a-b|+|b|$$
Attempt:$$a=a-b+b$$
$$|a|=|a-b+b|$$
Looks good.
