Derviation of Moment of inertia
The discussion centers on the concept of Moment of Inertia (MI) in circular motion, defined as MI = mass × radius² (I = mr²). This relationship indicates that MI is proportional to the square of the radius from the axis of rotation, which is essential for calculating angular momentum (L = Iω). The confusion arises from the distinction between linear and angular motion, where linear force (F = ma) does not involve squaring the distance, unlike MI. The discussion clarifies that MI's dependence on the square of the radius is crucial for understanding torque (τ = Iα) and angular acceleration.
  • Understanding of basic physics concepts such as force, mass, and acceleration.
  • Familiarity with angular motion and torque.
  • Knowledge of Newton's laws of motion, particularly the second law.
  • Basic grasp of mathematical operations involving squares and proportionality.
  • Study the derivation of Moment of Inertia for various shapes (e.g., solid cylinder, sphere).
  • Learn about the relationship between torque and angular acceleration in rotational dynamics.
  • Explore the concept of angular momentum and its conservation in closed systems.
  • Investigate the applications of Moment of Inertia in engineering and physics problems.
Students of physics, mechanical engineers, and anyone interested in understanding the principles of rotational dynamics and their applications in real-world scenarios.
anmolnanda
our lecturer defined MI as inertia of body in circular motion(i don't know anything about inertia)
except that it is something to oppose
my question is that
when M.I in circular motion depends on both mass and radius(distance from axis) of the body.
why MI is represented as mr^2 why is it not mr
how can some quantity depend on the square of another term when they are also directly prop. to that quantity without square...
Why do you think it should be mr? Momentum of inertia *depends* on the radius from the axis of rotation, but is not *proportional* to the radius. In fact it is proportional to the square of the radius. It is defined this way so that (momentum of inertia) times (angular velocity) = (angular momentum).
my question is why is the square
force=ma
not
force=ma^2
Newton's law is a completely separate equation. Perhaps you are confused by the terminology "moment of inertia"?
Newton's second law is (force) = (mass) * (acceleration). It tells you the rate of change of an object's velocity if you apply a given force to it.
Moment of inertia is defined by (moment of inertia) = (mass) * (distance from axis of rotation)^2. In conjunction with the equation (torque) = (moment of inertia) * (angular acceleration) it let's you find the rate of change of angular velocity if you apply a torque. Moment of inertia is kind of an analog to mass: if something has a large mass, you have to apply a large force to accelerate it much. If something has a large moment of inertia, you have to apply a large torque to get it to rotate very quickly.
i am just confused or i mean trying to figure out why some quantities depends on square of a given quantity and some degree of 1 of it...
hi anmolnanda! :smile:
"moment of …" means "r cross …", so anything with moment has an extra r :wink:
(and you can take any formula like F = ∫ a dm, do "r cross" of the whole thing, and get another formula …
in this case, r x F = ∫ r x a dm = ∫ r x (r x α) dm, or τ = Iα)
Suppose a particle of mass m is attached to a pivot by a thin rod of length r . As the particle travels around the circle, we know that the distance it travels is equal to the angle the rod sweeps out measured in radians multiplied by the radius r . Differentiating twice shows that
a = r A
where A is the angular acceleration (i.e. the rate at which the angular velocity of the rod is changing) and a is the instantaneous linear acceleration the particle experiences out on the circle.
By Newton's second law for linear motion, if we apply a force F to the particle, then F = m a . On the other hand, since we have a rotating system, we would like to work with torque , instead of force, so we multiply both sides of the equation by r . Then
T = F r = m r a .
Finally, we use the equation derived about, to convert from linear acceleration to angular acceleration:
T = m r a = m r (A r ).
Rearranging terms gives the desired formula T = (m r 2) A.
  • · Replies 30 ·
  • · Replies 30 ·
  • · Replies 27 ·
  • · Replies 0 ·
