Describe the angular momentum of the ball and net torque on
The discussion focuses on understanding the angular momentum and net torque of a ball in a physics problem. The angular momentum (L) is determined to be in the k direction, while the net torque (τ) is concluded to be zero. Participants clarify that the forces acting on the ball include tension from a rope and a magnetic force, which ultimately cancel each other out, resulting in zero torque. The right-hand rule is emphasized for determining the direction of angular momentum and forces. The conversation concludes with a consensus on the calculations and concepts involved in the problem.
heartshapedbox
  1. At the instant illustrated, which best describes the angular momentum of the ball and net torque on the ball, as measured around the origin?
    L⃗ is in the kˆ direction, ⃗τ is 0.
torque= (F)x(r)
Tension in rope= (mv^2/r)+qvb
I am at a loss, I do not understand this word problem. Can this please be explained?
Is this a multiple choice problem? I'm not sure I understand what you mean by which best describes the angular momentum.
This is the complete problem, I do not know how to do #3. :) Thanks!
Do the three stars indicate anything in particular (***)?
Anways, what you have is a problem where you must determine what forces are acting on the particle, and how they influence the torque and angular momentum. Recall that \vec{\tau} = \vec{r} \times \vec{F} and \vec{L} = \vec{r} \times \vec{p}. The right hand rule will come in handy. There is a rope, so that will apply a force of tension on the particle. There is also a magnetic field, which way will the force point due to that?
the correct answer is marked by "***" :)
Ok thank you, I believe I understand. Right hand in direction of velocity, curl towards r, L is out of the page, so k direction.
Right hand in direction of velocity, curl towards F (there is the force of B and the centripetal force) they point in opposite directions, so they cancel, making torque zero?
Yes right hand in direction of velocity (and so linear momentum), curl towards r, so L points in positive k. For torque you should be looking at the direction of the Forces, and crossing them with r. Note that the tension points towards the centre, and the magnetic force points away (F =qv x B). So if you cross them with respect to the r vector, do they contribute to torque? But yes in the end the torque is zero.
Likes heartshapedbox
