Design and Fabrication of a scaled down deLaval nozzle.
  • Thread starter Thread starter MdAsher
    Design Nozzle
The discussion focuses on the design and fabrication of a scaled-down deLaval nozzle to achieve supersonic velocity in a laboratory setting. Key design parameters include inlet diameter, throat diameter, divergent diameter, cone angle, and nozzle length. While basic algebra can calculate area ratios, a more detailed understanding of the method of characteristics and rudimentary CFD is necessary for accurate design. Recommended literature includes "Elements of Gasdynamics" by Liepmann and Roshko and "Modern Compressible Flow" by Anderson for in-depth knowledge.
  • Understanding of fluid dynamics principles
  • Familiarity with the method of characteristics
  • Basic algebra for area ratio calculations
  • Knowledge of compressible flow theory
  • Study the method of characteristics for nozzle design
  • Learn about the impact of boundary layers on nozzle performance
  • Research the design of supersonic nozzles using CFD tools
  • Explore advanced topics in compressible flow from "Modern Compressible Flow" by Anderson
Engineers, aerospace students, and researchers interested in fluid dynamics and nozzle design will benefit from this discussion.
MdAsher
Greetings Everyone,
I am lookin forward to design a simple deLaval nozzle to achieve supersonic velocity in lab. I do not want to follow the cfd method or any other software method as of now. If someone could please guide me with calculating the various design parameters of the nozzle like inlet diameter, throat diameter, divergent diameter, cone angle and length of the nozzle.
Thank you.
You can certainly calculate the area ratios in question using only some algebra but if you are wanting to determine the length and shape of that divergent section you'll need more detail than just "how long should it be" and you'll need at least rudimentary CFD. Without using a computer, doing the method of characteristics to determine these parameters would be daunting.
For example, what Mach number do you want to achieve? How large do you want it to be (i.e. what are the maximum dimensions you could tolerate)? Do you want to expand the flow to the exit as quickly (in space) as possible or do you want a longer, smoother nozzle? How accurate does your final Mach number have to be (i.e. do you need to account for the nozzle wall boundary layer in the design)? Do you want it to be 2D (rectangular exit) or axisymmeteic (circular exit)?
These are the kinds of bits of information you need to know if you want to design a nozzle for real. Now, you may be able to get away with just knowing the exit-to-throat area ratio and then machining anything that fits the bill, but we don't know that based on what you asked.
Thank you sir, would you please suggest me some books werin I can read indepth about nozzle design?
Thank you sir, it's really helpful. I have started with Liepmann, starting to get a better picture.
Thank you sir
  • · Replies 52 ·
  • · Replies 16 ·
