Designing Sun Tracker w/ GPS | Get Ideas & Suggestions
  • Thread starter Thread starter Essadaoui_Red
    Gps Sun
The discussion revolves around designing and building a sun tracker that utilizes GPS to locate the position of the sun and orient photovoltaic panels accordingly. Participants explore the technical challenges and programming requirements involved in creating a system that can operate universally across different geographical locations.
  • One participant suggests that the sun tracker should be able to locate its position via GPS and calculate the sun's position to orient the photovoltaic panels.
  • Another participant questions the relevance of GPS for determining the sun's position, asking how a device would "move towards this position."
  • A different participant notes that if the photovoltaic panels are not mobile, a GPS may not be necessary, proposing the use of a real-time clock and initial latitude/longitude settings instead.
  • Concerns are raised about the programming required to calculate the sun's position in real time and how to convert this information into control signals for the tracker.
Participants express differing views on the necessity and role of GPS in the sun tracking system, indicating that multiple competing perspectives exist regarding the design and functionality of the tracker.
There are unresolved questions about the assumptions underlying the use of GPS for sun tracking and the specific programming challenges that need to be addressed for real-time calculations.
Essadaoui_Red
Hello,
we try to design and build a sun tracker carrying a plate photvoltaîque, piloted by GPS,
GPS must locate the position of the sun and gives an order to move towards this position throughout the day,
but we really do not know where to start
all your suggestions and ideas will be welcome,
thank you in advance for your helps,
cordially
Essadaoui_Red said:
Hello,
cordially
Sounds like a school project, so we need to hear your thoughts before we can offer any tutorial hints.
And if your PV panels are not mobile, you don't need an active GPS attached, right? Just a real-time clock, and an initial Lat/Long setting...
I don't understand what you are trying to achieve.
A GPS unit will tell you where it is on the surface of the Earth.
What does that have to do with the position of the sun in the sky? And how would a device" move towards this position"?
Hello,
we try to build an universal sun tracker, means that it work in any where (africa,USA, UE...), the system should localise it's position via GPS, and calculate the position of the sun...and orients th PV to the sun...
the problem is in the program that calculate the position in real time ? and how can we transform these informations to control signal ?
thank you
9K
