Determinant of Matrix Component
11 replies · 2K views · last reply
member 428835
Show $$\frac{\partial \det(A)}{\partial A_{pq}} = \frac{1}{2}\epsilon_{pjk}\epsilon_{qmn}A_{jm}A_{kn}$$
##\det(A)=\epsilon_{ijk}A_{1i}A_{2j}A_{3k}##
$$\frac{\partial \det(A)}{\partial A_{pq}}=\frac{\partial}{\partial A_{pq}}\epsilon_{ijk}A_{1i}A_{2j}A_{3k}\\
=\epsilon_{ijk}\frac{\partial}{\partial A_{pq}}A_{1i}A_{2j}A_{3k}$$
but I'm now stuck. I feel like one of the ##A## components on the RHS must go to 1 and the rest would be constant, leaving some sort of ##\epsilon A_{yy} A_{xx}## behind. I'm thinking along the lines of ##\partial A_{ij}/\partial A_{ik} = \delta_{jk}##. Any ideas?
joshmccraney said:
Any ideas?
I'd be tempted to move ##A_{pq}## to the top-left of the matrix.
Are you suggesting take
$$\frac{\partial \det(A)}{\partial A_{11}}=\frac{\partial}{\partial A_{11}}\epsilon_{ijk}A_{1i}A_{2j}A_{3k}\\
=\epsilon_{ijk}A_{2j}A_{3k}\frac{\partial}{\partial A_{11}}A_{1i}\\
=\epsilon_{1jk}A_{2j}A_{3k}$$
One way to do it is just to do it for all 9 elements. Not very elegant.
Otherwise, you need to get a general expression for the terms that have ##A_{pq}## in them. It might be easier to rearrange the matrix, getting ##A_{pq}## to the top left corner.
Agreed!
What do you mean "general expression"? Also, you suggest getting ##A_{pq}## to the top left, doesn't this mean making ##A_{pq}=A_{11}##?
joshmccraney said:
Agreed!
It means using row and column operations. Alternatively, express the determinant in an equivalent form for expansion via the ##p##th row.
Since the determinant is a scalar, I'm unsure how to express it for the ##p##th row. Could you elaborate?
You can evaluate a determinant using any row as your starting row.
But, in fact, if you permute the rows to get the ##p##th row at the top, with row ##p+1## second and row ##p+2## third (where these are numbers modulo 3), I think it comes out easily enough. Then permute the columns to get the colums in order ##q, q+1, q+2##.
Then, if you do the same trick with the Levi-Civita, I think the equation should drop out for general ##p, q##.
PS by the same trick, I mean that:
##\epsilon_{pjk} = 1## when ##j = p+1## and ##k = p+2##
##\epsilon_{pjk} = -1## when ##j = p+2## and ##k = p+1##
And is ##0## otherwise.
I agree.
I don't think I'm understanding what you're saying. Could you illustrate, perhaps with a different problem? I just don't know the technique you suggest.
I agree.
Suppose we take the case ##p, q = 1, 1##:
##det(A) = A_{11}(A_{22}A_{33} - A_{23}A_{32}) + \dots##
Where the rest of the terms do not involve ##A_{11}##, hence you can calculate the required partial derivative.
You can also check fairly easily that:
##\frac{1}{2}\epsilon_{1jk}\epsilon_{1mn}A_{jm}A_{kn} = A_{22}A_{33} - A_{23}A_{32}##
Now, by either two row operations or no row operations and two column operations or no column operations, you permute ##A_{pq}## to the top left of your determinant. You need to check this for ##p, q = 1, 2, 3##. And, this gives
##det(A) = A_{pq}(A_{p+1, q+1}A_{p+2, q+2} - A_{p+1, q+2}A_{p+2, q+1}) + \dots##
Where we are using modulo 3 here. And that's just about it. All you need to do is manipulate the expression involving the Levi_Civita coefficients using a similar modulo 3 approach.
