Determination of a dominant and a recessive trait or gene
The determination of dominant and recessive traits is fundamentally based on biochemical mechanisms. For instance, the widow's peak trait is dominant due to its allele's ability to express a functional protein, while the straight hairline allele is recessive. Conditions like cystic fibrosis illustrate how a recessive allele can be non-functional due to mutations in the cystic fibrosis transmembrane conductance regulator (CFTR) gene. Dominant negative alleles can inactivate functional copies, while gain-of-function mutations, such as those seen in lactase persistence, can lead to dominant traits by enabling new functions.
  • Understanding of basic genetics terminology, including alleles and traits
  • Knowledge of gene expression and protein function
  • Familiarity with genetic mutations, specifically gain-of-function and loss-of-function mutations
  • Awareness of genetic disorders, such as cystic fibrosis
  • Research the biochemical mechanisms of widow's peak inheritance
  • Study the role of cystic fibrosis transmembrane conductance regulator (CFTR) in genetic disorders
  • Explore dominant negative alleles and their impact on gene function
  • Investigate the genetic basis of lactase persistence and its evolutionary significance
Genetics students, researchers in molecular biology, and anyone interested in understanding the mechanisms of inheritance and gene expression.
Xena Dean
What determines if a gene or trait will be dominant over another or not? For instance, we take the example of widow's peak. This gene has two alleles. One for widow's peak which is the dominant one, and another for straight line, which is the recessive one. But why the widow's peak is dominant and the straight line is recessive? What is the reason behind the a dominant gene being dominant and the excessive being recessive?
Biology news on Phys.org
Whether an allele is dominant or recessive depends on the exact biochemical mechanisms at work. Many times a "broken" version of a gene is recessive. For example, cystic fibrosis is caused by a mutation in an ion channel called the cystic fibrosis transmembrane conductance regulator (CFTR) that prevents the ion channel for working properly. The disease allele is recessive because one functioning allele is sufficient to make enough CFTR for the body to behave normally. Only when both copies of the gene are non-functional does the disease occur.
Some "broken" version of genes, however, will inactivate the functioning copies of the genes and thus behave as dominant alleles (these are referred to as dominant negative alleles as they are dominant alleles that cause a loss of function). This is especially common when the proteins encoded by the genes function in a complex and one broken subunit in the complex is enough to render the entire complex non-functional. Another way for an allele to be dominant is though a gain-of-function mutation, in which the allele confers its trait by performing some new function (for example, an enzyme that cannot be turned off properly). A good example is lactase persistence. Normally, humans turn off production of the enzyme required to digest lactose in milk after childhood. Mutations can "break" the body's ability to turn off the gene, leading to production of the enzymes into adulthood. Even if only one copy does not get turned off into adulthood, this is sufficient to allow lactose digestion into adulthood.
I am not so familiar with the mechanisms behind widow's peak, so I don't know specifically what is happening in that case.
Here's a particularly good explanation of the topic with more examples:
https://genetics.thetech.org/ask-a-geneticist/genotype-vs-phenotype
Thank you for explaining :)
  • · Replies 16 ·
