Determine co-ordinates of points B?
  • Topic:
  • Thread starter Thread starter ai93
    Points
3 replies · 3K views
ai93
I have an equation of a line question
a) Find the equation of the straight line with gradient 2 passing through point A (-4,3)
I worked out the equation of the line, which is, y=2x+11.
But having trouble with question b) and c)
b) if the line in part a) intersects the line y=x+8 at point B, determine the co-ordinates of point B.
c) Find
i) the length
ii) the gradient
Mathematics news on Phys.org
a) This is the correct line. (Yes)
b) Okay, you have two lines:
$$y=2x+11\tag{1}$$
$$y=x+8\tag{2}$$
To find the coordinates of point $B$, where the two lines intersect, you must solve the simultaneous system above. Since we have both lines in function form, we can just equate the two:
$$2x+11=x+8$$
Solve this for $x$, and then substitute the resulting value for $x$ into either (1) or (2) to get the $y$-coordinate.
For part c), I am assuming you are to find the distance between $A$ and $B$, and the gradient or slope between the two points.
Distance formula:
$$d=\sqrt{\left(x_2-x_1\right)^2+\left(y_2-y_1\right)^2}$$
Slope formula:
$$m=\frac{\Delta y}{\Delta x}=\frac{y_2-y_1}{x_2-x_1}$$
Can you proceed?
$$y=2x+11\tag{1}$$
$$y=x+8\tag{2}$$
$$2x+11=x+8$$
Distance formula:
Slope formula:
Can you proceed?
Thanks!
$$2x+11=x+8$$
$$2x-x=8-11$$
$$\therefore x=-3$$
sub $$x=-3 into y=2x+11$$
= y=5
for c) Why is finding the distance necessary? Since we have to use the gradient/slope formula?
Nevertheless
m=$$\frac{5-3}{(-3)-(-4)}$$
m=2
:D
Yes, everything looks correct. :D
You asked why do we need the distance formula...well, you originally posted that you need the length, and I assume you are being asked to find the length of line segment $\overline{AB}$.
