Determine currents Ia, Ib and Ic
  • Thread starter Thread starter agata78
    Currents Ib Ic
62 replies · 12K views
Im sorry but i wasted your time and mine too. I didnt mention in task that i need to use mesh -current analysis. I need to come back to previous idea you gave me!
No worries. Solve symbolically for the currents, then hammer away at the complex math. Watch for shortcuts (compare the denominators of the symbolic expressions for Ia and Ib).
I will try to come back to this then and see where i go:
Loop1:
+12 - Ia47 - (Ia + Ib)j100 = 0
Loop2:
+10 - Ib(-j75) - (Ia + Ib)j100 = 0
12- Ia47 - (Iaj100+Ibj100) =0
12- Ia47- Iaj100- Ibj100=0
-Ia47 - Iaj100= Ibj100-12 x(-1)
Ia(47+j100)=-Ibj100+12
Ia= (12- Ibj100) / (47+j100)
do i have to calculate 2 loop after when i found Ib ?? and to calculate Ib do i have to calculate it from Loop1 or loop2?
When i was in Secondary School in Poland, we used 2 equations together:
ex, a+ 2bx=2
3a + bx = 2 / x(-2)
and then first equation stay the same
but second
a+ 2bx=2
-6a-2bx = -4
and then adding them together!
-5a = -2
a= 2/5
and then coming back to one of two equations to calculate b!
Can i use this way to calculate a and b?
I thought i could use it:
+10 - Ib(-j75) - (Ia + Ib)j100 = 0 / (-1)
-10+ Ib(-75j) + (Ia+ Ib) j100 =0
2-Ia47 - Ib75j =0
Ia= (Ib75j+2 ) / 47what do you think?
You can do that, but when you add the equations one of the variables should be eliminated. You'll have to scale one of the equations so that the coefficients on one of the variables match accordingly.
What you mean by:
I tried to do that but my figures are not great. Maybe its not the best idea!
12-Ia47 -(Ia+Ib)j100=0
10-Ib(-75j) - (Ia+Ib) j100=0
12-Ia47-Ia100j - Ibj100=0
-Ia47-Ia100j = -12+ Ibj100
Ia47 + Ia100j =12- Ibj100
Ia(47+ 100j) = 12- Ibj100
Ia= (12- Ibj100) / (47+100j)
do you agree with me?
i went further more:
((12 - Ibj100) (47-100j)) / ((47+100j) (47-100j))
(564-1200j-4700jIB +Ibj2 (10000) ) / ((2209-J4700+ j4700- J2 (10000) )
(564-1200j-4700jIb-Ib10000 ) / ( 2209+10000)
564-1200j- Ib(4700j-10000) / 12209
and i don't know what to do next?
Should i first calculate a and b from first loop and check it out with second one?
Looks okay!
Probably not worth doing anything else with the first loop equation once you've isolated one of the variables from it. Move on to the second loop equation.
Isolate one variable from the first equation (you isolated Ia above). Substitute that expression for Ia into the second equation. That'll leave you with an equation in one unknown, Ib. Solve for Ib.
Can i just use for a:
Ia= (12- Ibj100) / (47+100j) or 564-1200j- Ib(4700j-10000) / 12209
Which one would be easier one?
I think that they'll turn out to be equally difficult once substituted into the second equation.
The method you proposed of adding (or subtracting) equations to eliminate one variable has merit in this regard. It accomplishes the task of obtaining one equation in one unknown for one of the variables without having to go through substitution and expansion of complex values.
For example, if you collect the terms of the two loop equations on the unknown variables:
(1) 12 + (-47 - 100j)Ia - 100jIb = 0
(2) 10 - 100j Ia - 25jIb = 0
If you multiply the second equation by -4 then you can add them and eliminate Ib, yielding an expression involving only Ia:
(2) -40 + 400j Ia + 100jIb = 0
-28 + (47 + 300j)Ia = 0
This is a much cleaner path to finding one of the currents.
Yes it looks actually quite nice and clear ( if you know what i mean)
I will take this path!
agata78 said:
Thanks, i checked it out, looks ok but quite complicated for me. but for sure i will try to purchase software to help me with calculation asap!
Scilab is free and is nearly as powerful as the more common Matlab and Mathcad:
http://www.scilab.org/
It will take you a while to learn to use it, but that effort will be worthwhile.
Ia= (1316 -8400j ) / 92209
and now i can use any loop to find Ib
Yes?
-28 + (-47 + 300j)Ia = 0
There's a sign error here.
agata78 said:
Ia= (-1316 -8400j ) / 92209
Yes?
Sign error propagated to here.
D'oh! Yup, The Electrician has spotted a sign error that I made above. I dropped the "-" on the "47" when I transcribed it for the sum. Thank you T.E. This is why I like math software!
@agata78: Yes, after repairing the sign, use that value for Ia in one of the loop equations to find Ib.
Ia= 0.0142-0.009j
Ib= -0.057+ 0.0356j
i think its right, what do you think?
Its the same answer as previous one. But previous one had Ia= -0.014-0.09j and Ib= 0.057 + 0.0356j( not sure about that minus at front on Ia and plus on front of Ib)
Did you account for the sign error that The Electrician spotted? Both terms of Ia should turn out to be negative, and 8400/92209 is 0.0911.
I'm seeing Ib as +0.0571 - 0.0356j.
I changed every where for minus and now its correct!
I put the value for Ia into this equation
10-Ibj25-Iaj100=0
I think it doesn't have to be the first 2 loops!
anyway thank you for help.
I have two more questins to answer until tomorrow!
at the end it wasnt difficult but it took me almost two days to do that
Just to show how easy it can be.
Solving circuits usually ends up being a problem of solving a system of simultaneous equations. There is a way to write down a system of simultaneous equations that shows them in a very compact form. That way is to use matrix notation. Your two mesh equations can be shown in matrix form like this:
Solving simultaneous equations involves elimination of variables until a single equation in one unknown is obtained. That equation is solved for that unknown, and the result is then substituted in the remaining equations. Then another variable is solved for, and the process is continued until you have all the unknowns solved.
Once in this form, a linear solver can be used, which does all the elimination and back substitution for you, avoiding much mistake prone, tedious, algebra:
Here's how it looks on the HP50G calculator in matrix form:
And, after pressing one button, here's the solution:
It would be worth your while to learn how to do this. Don't forget the free software Scilab, but a handheld calculator is very convenient.
You've had enough practice doing it by hand. Learn to use a mathematical software or calculator!
Yeap its correct, i got the same!
Ia= -0.0142-0.009jbut Ib
10-Ibj25 - Ia100
10- Ibj25- ((-1316-8400j)/ 92209 ) x j100
10- Ibj25- (- 131600j- 840000j2) / 92209
-Ibj25= (-131600j + 840000 / 92209 ) -10
-Ibj25= (-131600j+840000-922090)/ 92209
-Ibj25= (-131600j- 82090) / 92209
-Ibj25= -1.427j - 0.8902
Ib= (-1.427j - 0.8902) / (-25)
Ib= 0.057j + 0.0356j
Can you check my calculations please?
Ia= -0.0142-0.0911jbut Ib
10-Ibj25 - Ia100
Ib= (-1.427j - 0.8902) / (-25j)
You left out a "j" in your last step.
Don't forget the numerical error involving -.0911 that gneill already mentioned.
See how easy it is to make a mistake? Just imagine trying to do this during an exam without making a single mistake!
Ib supposed to be= +0.0571 - 0.0356j.
mine is Ib= 0.057j + 0.0356j
Can you check my calculations:
10-Ibj25 - Ia100
You've made some kind of error in this last step. The sign in front of the 0.0356 is in fact minus if you do the complex arithmetic correctly.
This kind of error won't happen if you use a calculator that can do complex arithmetic.
Ib= 0.057j + 0.0356
Still i need minus inside, i checked a few times and it is plus!
10-Ibj25 - Ia100
Ib= (-1.427j - 0.8902) / (-25j) <---- at this point, multiply top and bottom by +j. What do you get?
You've got a sign issue occurring in whatever steps you take between the line indicated above and your final line.
but i don't understand why i have to multiply by +j
minus divide minus is plus
and i divide -25 both sides
I did multiply top and bottom by +J.
Ib= 0.057- 0.0356j
You want to clear the j from the bottom. So multiply top and bottom by j. Try it.
