Determine magnitude of force acting on block on inclined plane
The discussion focuses on calculating the force P required to move a 20-kg package up an incline, given the static and kinetic coefficients of friction both equal to 0.3. The calculated force to initiate movement is 419N, while the force during sliding is 301N. The participant utilized free-body diagrams and equations of motion, including kinematic equations, to derive the necessary expressions for force and acceleration. Discrepancies in calculations were noted, prompting further inquiry into the methodology used.
  • Understanding of Newton's laws of motion
  • Familiarity with free-body diagrams
  • Knowledge of kinematic equations
  • Basic concepts of friction, including static and kinetic coefficients
  • Review the derivation of forces on inclined planes using free-body diagrams
  • Study the application of kinematic equations in solving for acceleration
  • Explore the effects of friction on motion in inclined planes
  • Learn about the differences between static and kinetic friction in practical scenarios
Students studying physics, particularly those focusing on mechanics, as well as educators and anyone involved in solving problems related to forces on inclined planes.
JJBladester
A 20-kg package is at rest on an incline when a force P is applied to it. Determine the magnitude of P if 10s is required for the package to travel 5m up the incline. The static and kinetic coefficients of friction between the package and the incline are both equal to 0.3.
Answer: 419N to start and 301 during sliding
m=20kg
g=9.8m/s2
t=10s
xi = 0ft
xf = 5ft
μs = μk = 0.3
Frictional force = Ff = μN
First, I drew a free-body diagram including tilted coordinate axes:
Then, I went about finding the sum of the forces equations in the x- and y-directions.
\sum F_{x}=-F_{f}-mgsin(20)+Pcos(30)=ma
\sum F_{y}=N-mgcos(20)-Psin(30)=0
From the second equation,
N=mgcos(20)+Psin(30)
Plugging this value for N into Ff = μN in the first equation yields:
P=\frac{m\left(a+\mu gcos(20)+gsin(20)\right)}{cos(30)-\mu sin(30)}
If I know the acceleration, I can find the magnitude of P. There has to be a way to find acceleration from the initial conditions, but I'm at a loss. Also, once static friction is overcome, I'm sure the sum of the forces equations will be different but I'm not sure how.
Well since the force seems to be constant, you could apply the kinematic equation to solve for the acceleration:
x = x_0 + v_0t + (1/2)at^2
From the \sum F_{x} equation, along with F_{f}=\mu N:
a=-\mu gcos(20)-\frac{\mu Psin(30)}{m}-gsin(20)+Pcos(30)
x_{f}=x_{i}+v_{i}t+\frac{1}{2}at^{2}
5=\frac{1}{2}\left (-\mu gcos(20)-\frac{\mu Psin(30)}{m}-gsin(20)+Pcos(30) \right )\left (10^{2} \right )
\frac{1}{10}=-\mu gcos(20)-\frac{\mu Psin(30)}{m}-gsin(20)+Pcos(30)
\frac{1}{10}+\mu gcos(20)+gsin(20)=P\left (cos(30)-\frac{\mu sin(30)}{m} \right )
P=\frac{\frac{1}{10}+\mu gcos(20)+gsin(20)}{cos(30)-\frac{\mu sin(30)}{m}}=\frac{\frac{1}{10}+(0.3)(9.8)cos(20)+(9.8)sin(20)}{cos(30)-\frac{0.3sin(30)}{20}}\approx 7.24N \neq \: Book's\: answer\: of\: 419N
Did I do the math wrong? Where do I go from here?
  • · Replies 19 ·
