Determine Series' Convergence or Divergence
11 replies · 2K views · last reply
knowLittle
##\sum _{n=1}ne^{-n}##
Ratio Test
Integral Test
I know that by the ratio test, it converges absolutely. But, I am unable to determine its convergence through the integral test . Could someone help? I thought that the integral test would be best, since e is used.
The ratio test gives me 1/e approx 0.367879 <1; therefore, it converges absolutely.
Now, the integral test is my concern. I believe I have done all correct steps, but the result shows that it diverges.
##\lim _{b\rightarrow \infty }\int _{1}^{b}\dfrac {n} {e^{n}}dn##
Integrating by parts with: u=n; du=dn; dv=(e^-n) dn; v=-e^-n
## \left[ -e^{-n}\left( n\right) +-e^{-n}\right] _{1}^{\infty }##
The final result is:
##-\dfrac {\infty } {e^{\infty} }-\dfrac {1} {e^{\infty }}+\dfrac {2} {e} ## and it diverges. What am I doing wrong?
Thank you.
Ratio Test
Integral Test
Thank you.
What is ##\displaystyle \lim_{n \rightarrow \infty} \frac{n}{e^n}##? You will need to use l'Hospital's rule!
My integral after L'Hospital doesn't agree with answers online. Could you tell me what's wrong?
##\int _{1}^{b}\dfrac {1} {en}dn=\left[ -e^{-n}\right] _{1}^{b}=-\dfrac {1} {e^{\infty }}+\dfrac {1} {e}##
, the first term to the left is e^n
You need to find the limit of [itex]\frac{1}{e^n}[/itex] and not its integral.
The limit of (1/ e^n) as n approaches infinity is 0. The test for divergence is inconclusive.
I'm trying to find the determination of convergence or divergence through the integral test.
OK, I've worked it out, and the limit should be: [itex]\frac{2}{e}[/itex]
Yeah, that's what it's shown online.
I get 1/e. My procedure is above. Could you help?
This step is correct:
[tex]\left[ -e^{-n}\left( n\right) -e^{-n}\right] _{1}^{\infty }[/tex]
Let b=∞, then,
[tex]\left[ -e^{-n}\left( n\right) -e^{-n}\right] _{1}^{b}[/tex]
This gives:
[tex]\left[ \left( \frac{-b}{e^b} -e^{-b}\right) - \left( \frac{-1}{e} -e^{-1}\right) \right][/tex]
Now, what you have to find is the limit as b→∞
[tex]\lim_{b→∞} \left[ \left( \frac{-b}{e^b} -e^{-b}\right) - \left( \frac{-1}{e} -e^{-1}\right) \right][/tex]
But the limit of the following requires using L'Hopital's rule,
[tex]\lim_{b→∞} \frac{-b}{e^b} = \lim_{b→∞} \frac{-1}{e^b}[/tex]
You can then work out the rest:
[tex]\lim_{b→∞} \left[ \left( \frac{-1}{e^b} - \frac{1}{e^b}\right) - \left( \frac{-1}{e} - \frac{1}{e}\right) \right][/tex]
Thanks, it's what I suspected. This L'Hospital rule keeps coming and coming.
You had the answer in your first post! The first term goes to zero by l'Hospital's, the second goes to zero, and the final term is just a constant which was ##\frac{2}{e}##.
I know, I didn't know I could use L'Hospital in the middle of an integration by parts.
Thanks.
