Determine the particle's equation of motion
The particle's equation of motion is derived from its maximum speed and spring constant, resulting in the function x(t) = 2sin(10t + π). The particle has a mass of 0.500 kg and is attached to a spring with a force constant of 50.0 N/m. The discussion also addresses the calculation of time intervals for the particle's movement and the importance of considering multiple angles for the sine function when solving for time. The correct approach involves using arcsin and understanding the periodic nature of the sine function.
  • Understanding of harmonic motion and spring dynamics
  • Familiarity with trigonometric functions and their properties
  • Knowledge of angular frequency calculations
  • Ability to solve equations involving inverse trigonometric functions
  • Study the derivation of equations of motion for simple harmonic oscillators
  • Learn about the implications of phase shifts in sinusoidal functions
  • Explore the relationship between kinetic and potential energy in oscillatory systems
  • Investigate the properties of the sine function and its periodicity
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators seeking to clarify concepts related to harmonic motion and energy conservation.
Sheneron
A particle with a mass of 0.500 kg is attatched to a spring with a force constant of 50.0 N/m. At time t = 0 the particle has its maximum speed of 20.0 m/s and is moving to the left. (Use t as necessary.)
(a) Determine the particle's equation of motion, specifying its position as a function of t, time.
(b) Where in the motion is the potential energy three times the kinetic energy?
(c) Find the length of a simple pendulum with the same period.
(d) Find the minimum time interval required for the particle to move from x = 0 to x = 1.00 m.
I only need help with the first part for now, but here is what I tried.
\omega = \sqrt{\frac{k}{m}}
\omega = 10
v_{max} = A\omega
A = 2
So my equation of motion looked like this.
x(t) = 2cos(10t)
but that was wrong and I am not entirely sure why
You are off by a phase factor. Note that at t = 0 the particle is at max speed--so what's its position with respect to equilibrium?
It's position, with respect to equilibrium, would be 0, which means the phase factor needs to be pi?
Right.
Write the general expression and see if that works.
Ok that worked and I am on part D) now.
x(t)= 2sin(10t + pi)
I set x to 1 and solved for t but that didn't work. Can you not do that?
That should work fine. What did you get? (Remember that you're working in radians.)
\frac{sin^{-1}(.5)-\pi}{10}
that gives me a negative .261
perhaps I am not doing my algebra right?
Two things you need to do:
(1) Choose a value of sin^{-1}(.5) that gives you a positive time.
(2) Figure out the times when x = 0. (t = 0 is one such time, but it's not the one you want. At t = 0 the particle is moving left; you want the time when it's moving right.)
but my time = all that stuff, and sin of .5 - pi always comes out a negative number..
Realize that there's more than one angle that satisfies \sin\theta = .5.
For arcsin of 0.5 I get a value of 0.52359, so you are saying there is another value in addition to this?
Can anyone that is still awake help me solve part D?
I think you've figured it out by now, but sure:
\sin\theta = \sin(\theta + 2\pi)
That's just one example (but it's the one you need). Look at a graph of a sine function and see all the places where it equals .5.
I figured it out, but I still didn't understand it, so I am glad you posted again.
  • · Replies 19 ·
