How Do You Calculate the Charges on Two Pieces After a Split?
  • Thread starter Thread starter scholio
    Charge Particle
To solve the problem of calculating the charges on two pieces after a split, the total charge of 25 microcoulombs must be conserved. The force of repulsion between the pieces is given as 1000 Newtons when they are 3 cm apart. By using the equation F = k(qa)(qb)/r^2 and substituting qb as (25*10^-6 - qa), a quadratic equation in terms of qa can be derived. After solving the quadratic, the charges qa and qb were found to be approximately 1.99*10^-5 coulombs and 5.05*10^-6 coulombs, respectively, which sum to the original charge. The calculations confirm that the approach and final values are correct.
scholio
a charged object having 25 microcoulombs on it breaks into two pieces. if the force of repulsion between the two pieces i 1000Newtons when the pieces are 3cm apart, what is the charge on each piece? assume pieces act as a point charges
E = F/qtest = k(qa)/r^2 where F is the attractive/repulsive force
F = k(qa)(qb)/r^2 where k is 9*10^9, qa is charge of one piece, qb is charge of other piece, r is the radius between pieces
firstly, do i assume the parts broken into are the same size/charge as each other? i don't think so, correct?
basically i used the second eq and set F = 1000, r = 0.03m, k = 9*10^9 and solved for qa in terms of qb
i then used the first eq and subbed in F =1000, qtest = 25*10^-6 coulombs and set that equal to kqa/r^2, where i subbed in what i got from the second eq in for qa and solved for qb
i got 2.5*ac^-5 coulombs for qb, i used qb in the second eq and got a qa of 4*10^-6
i know i did something wrong because when i sum the charges of each piece, qa and qb, i get less than the entire charge value given (25 microcoulombs). i get a sum of 2.9*10^-5 coulombs
is my approach even close, help appreciated...
OK you starting from the right place, but I think you making this more complicated than it has to be:
F=1000N=\frac{kq_aq_b}{r^2}
The problem is that you have two variables, q_a and q_b.
HINT: Can you plug in and expression for q_b in terms of q_a in the above equation using what you know? Think conservation of charge. If so, you should then be able to solve for q_a, and thus, q_b using the expression you used previously.
how about substituting in (25*10^-6 - q_a) in for q_b where 25*10^-6 is 25 microcoulombs?
when i subbed that in for q_b the eq you gave produced a quadratic equation in terms of q_a, i did the quadratic formula and got 225415.9 and -415.9
i'm not too sure on units because it is coulombs that is impossible... help?
__________%%%%%%%%%%%%%%%%%%%%%%%________________
actually i incorrectly calculated the quadratic eq, for q_a i got 1.99*10^-5 and 5.05*10^-6 coulombs, which one do i use for q_a? I'm guessing the second one...
well i chose correctly because when i subbed that value back in and solved for b i got 1.98*10^5
so q_a + q_b = 2.5*10^-5 =25*10^-6 = 25 microcoulombs
1.98*10^-5 + 5.05*10^-6 = 2.5*10^-5
YES correct!
Thanks so much G01
Anytime. Good Job! :smile:
  • · Replies 18 ·
9K
  • · Replies 21 ·
