Determining the Charge on Parallel Plates
The discussion focuses on calculating the charge on parallel plates given an electron's initial and final velocities, distance between the plates, and physical constants. The user initially calculated the electric field using the formula E = ma/q, resulting in E = 6.823 x 10-6 N/C. Subsequently, they applied the equation Q = EA/4πk to find the charge Q = 3.89 x 104 C, which does not match the answer key's value of 1.13 x 10-13 C. Participants suggest verifying the acceleration and electric field calculations, emphasizing the need to derive the electric field between two plates using Gauss's law.
  • Understanding of kinematic equations, specifically V_f = V_i + a*t and d = (V_f + V_i)/2 * t.
  • Familiarity with Newton's second law, F = ma.
  • Knowledge of Coulomb's law and electric fields, particularly E = F/q.
  • Basic grasp of Gauss's law and its application to electric fields between parallel plates.
  • Learn to derive the electric field between two parallel plates using Gauss's law.
  • Study the relationship between electric field strength and charge density.
  • Review kinematic equations for calculating acceleration in electric fields.
  • Explore the implications of charge distribution on electric field strength in parallel plate configurations.
Students in introductory physics courses, particularly those studying electromagnetism, as well as educators seeking to clarify concepts related to electric fields and forces on charged particles.
Brandone
An electron starts from one plate of a charged closely spaced (vertical) parallel plate arrangement with a velocity of 1.63x104 m/s to the right. Its speed on reaching the other plate, 2.10 cm away, is 4.15x104 m/s.
If the plates are square with an edge length of 25.4 cm, determine the charge on each.
Given and Known:
vi = 1.63x104
vf = 4.15x104
d = 2.10 cm
A = (25.4 cm)2 = (0.0645 m2)
me = 9.109x10-31 kg
qe = 1.602x10-19 C
k = 9.00 x 109 Nm2/C2
a = (vf-vi) / (tf-ti)
F = ma
E = Fq / q
Q = EA / 4[pi]k
First, I used:
F = ma, and
E = Fq / q
And got:
E = ma / q
E = (2.52x104-N/C) (9.109x10-31 kg) / (1.602x10-19 C)
Then,
Q = EA/4[Pi]k
Q = (6.823 x 10-6 N/C) (0.0645 m2) / 4[Pi](9.00x109 Nm2/C2
Q = 3.89 x 104 C
So, this does not agree with the answer key's 1.13x10-13 C, but it seems like I'm making sensible steps toward the answer.
Guidance, please?
Using the kinematic equation vf^2 - vi^2 = 2*a*s, find a.
F = ma = E*q
Given and Known:
vi = 1.63x104
vf = 4.15x104
d = 2.10 cm
me = 9.109x10-31 kg
qe = 1.602x10-19 C
F = ma
E = Fq / q
Q = EA / 4[pi]k
First, I used:
F = ma, and
E = Fq / q
And got:
E = ma / q
Then,
Q = EA/4[Pi]k
Q = 3.89 x 104 C
Guidance, please?
Use the kinematic equations V_f = V_i + a*t
and d = \frac{ V_f + V_i}{2}*t
to solve for the acceleration the electron has between these two plates
use F = ma to solve for the force the electron experiences,
then part of Coulomb's law relating to the super positioning of electric fields states that
F = QE, where F is the force the particle experiences, Q is the charge of the particle and E is the electric field strength,
using that you should be able to solve a number for the electric field,
however the next bit may be a little tricky, you will need to derive an expression for the electric field between two parallel plates,
to do this, you will need to apply Gauss's law,
\oint_S \mathbf{E}.d\mathbf{a} = \frac{1}{\epsilon_0}Q_{enc}
I'm not sure if I'm allowed to show you how to derive the electric field between two parallel plates (forum rules) but I can tell you that you'll need to draw a Gaussian pillbow, that extends above and bellow the plate,
in the equation above, your enclosed charge Q_{enc} = \sigma A where sigma is the surface charge density of the plate, and A is the area of the lid of the pill bow,
I'm not sure If I am allowed to show Brandone how to get an expression for the electric field between two plates,
It's not an easy thing to derive for an introductory physics forum
so I'm going to show him how I did it, if this is wrong, or against the forum rules(within reason) the mods can delete this post.
Gauss's law:
\oint \mathbf{E} . d\mathbf{a} = \frac{1}{\epsilon_0}Q
assuming the electric field is constant, (i.e plates stay at their charge)
also this is the electric field from a single plate
E \int d\mathbf{a}
= 2A|\mathbf{E}|
- going back to the original equation
2AE = \frac{1}{\epsilon_0}Qenc
Qenc is the total charge on the plate, = \sigma A
where A is the Area of the plate, and Sigma is the surface charge density of the plate
giving me the equation
2AE = \frac{1}{\epsilon_0}\sigma A
the As cancel out, and I can re arrange the equation as,
2E\epsilon_0 = \sigma
the surface charge density is the charge on the plate/area \sigma = \frac{Q}{A}
substituting
2E\epsilon_0 = \frac{Q}{A}
Q = 2E \epsilon_0 A taking out the 2 by taking into account this is the field for one plate, note two plates I get
Q = E \epsilon_0 A
This is the equation for the electric field between two plates with a charge difference of Q (I think)
http://teacher.pas.rochester.edu/phy122/Lecture_Notes/Chapter23/Chapter23.html
23.11 shows how the field is derived in a similar way, (easier to understand way if you ask me, compared to my Glaw method)
having the electric field of one sheet to be E = \frac{\sigma}{2\epsilon_0}
and between two sheets of opposite charge, you get E = Etop+Ebottom so the two cancels out
giving the same result I had.
I don't know from what dusty corner of my brain I pulled that equation for acceleration. Ugh... silly kinematics.
Vorcil, the issue with that, is that I'm to show all work, and there is no calculus in this classical course. If I work out the derivative on the homework, my professor would be rather curious, I'm afraid.
I had thought Q=EA/4[pi]k is the charge on a parallel plate configuration. Is that not it? I'm looking for total charge--not charge density.
Your formula is correct.
Check your acceleration and electric field.
