Determining the electric potential at a distance
5 replies · 8K views · last reply
Parad0x88
The electric potential of a very large isolated flat metal plate is 2000 V. The plate carries a uniform distribution of charge with surface density σ=1 μC/m2. Determine potential V at a distance x=1 cm from the plate. Assume that point x is far from the edges and that x is much smaller than the size of the plate.
To find the magnitude of the electric field I know I have to use: |E|=σ/2ϵ0
I'll be honest I have no clue how to solve this problem, any pointers in the right direction would greatly help!
Well, you've got E, and they are asking for potential, so what equation do you know which connects E and V ?
Would I be wrong in stating that since it's a very large plate with uniform charge density, it isn't a point charge. The formula that I have that links those two informations are:
ΔV = -∫Eds, and since the electric field is constant,
ΔV = -Es
ΔV = -σ/2ϵ0 times s
ΔV = -((1 μC/m2)/(2ε0)) times 0.01m
It seems like it's too simple solving like that, I feel like I'm missing something
That is the right answer. The question was more simple than you thought. The final step is to use the initial V and change in V to get the V 1cm away.
I'm not sure I understand what you mean by that last reply
If I read it right: The answer gives me ΔV, and I have VA, I want VB, right?
So I should do: ΔV = VB - VA ==> ΔV (That I found) = VB - 2000V
So ΔV + 2000V = VB (the volt at 1cm away)?
