Determining the radius of a concentric circle.
  • Thread starter Thread starter angela107
    Circle Radius
4 replies · 2K views
angela107
If two people were to have a pie, cut concentrically, what would the radius of the smaller disk be, such that the two individuals will have equal amounts of pie?.
n/a
A concentric cirlce has two circles with the same center, but a different radii.
We are given a pie with radius ##r##. A circular cut is made at radius ##r## such that the area of the inner circle is ##1/2## the area of the pie.
We know that the formula to calculating the area of a circle is ##πr²## or ##a=πr²## where ##a=1/2A##. Using substitution, we can determing a radius that will provide equal amounts of pie.
##0.5A=πr²##
##r²=0.5A/π##
##r= √(0.5A/π)##
Therefore, the two people will have an equal amount of pie if the radius ##r## of this smaller disk is equal to ##√(0.5A/π)##.
Can someone confirm if my work is correct?
What you write is confusing because you have used the symbol r to mean two different things. You said,"We are given a pie with radius r. A circular cut is made at radius r such that the area of the inner circle is 1/2 the area of the pie." So you used r for both the larger radius and the smaller radius. Why don't you call the radius of the whole pie R? I think your work is correct, but I think your should express your final answer for r in terms of R, and not in terms of the area A. If you do that, what do you get?
Assuming that A stands for area of the whole pie, do you need to know A in order to determine r?
Could you make r a function of R only, which is the easiest dimension to know?
This is correct, but you should give r in terms of the radius of the pie, which others in this thread are labelling R.
Sorry, I didn't notice I had two different R's! I will make a correction. Thank you :)
