Did the book misprint or am I doing something wrong?
  • Thread starter Thread starter kyin01
    Book misprint
kyin01
this is the question
find the volume of solid under the graph f(x,y) = x+ y above the region y^2 > x and 0 < x < 9
So pretty much I have the following integral set up
0 -> 9 dx
-sqrt(X) -> sqrt (X) dy
integrating over the function x+y
However, when I look at the solutions they did the same thing except for their dy, they took it over
0 -> sqrt (X)
is that a misprint or did I do something wrong? Because when I think about it, it's pretty much a parabola and nothing is restricting it from taking each end of the region
Where as the solutions is only taking half the parabola (from 0 to 9 along X axis which is agreed)
so is the solutions a misprint or did I do something wrong?
Unfortunately, it's hard to tell exactly what was intended since you are clearly not copying exactly what the problem said: "the region y^2> x and 0< x< 9" makes no sense. Perhaps they said "the region bounded by y^2= x, x> 0, x< 9"? Or did they possibly say "in the first quadrant"?
sorry it's
Find the volume of the region under the graph f(x,y)= x+y and above the region y^2 < x , 0 < x < 9
that is all they say
If 0<x<9, then 0<y<3,
so integrate in these limits (x+y) dx dy = 162
No. You are ignoring that the y limits are a function of x.
kyin01 said:
However, when I look at the solutions they did the same thing except for their dy, they took it over 0 -> sqrt (X)
That suggests a misprint or a misreading. Are you sure the problem doesn't say "above the region y^2 < x"? Even then, the y-integral should be from -\surd x to \surd x.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
