Difference between alpha-keto acid and keto acid
  • Thread starter Thread starter soopo
    Acid Difference
11 replies · 11K views
soopo
What is the difference between alpha-keto acid and keto acid?
I know that the difference is that alpha-keto acid contains an alpha carbon.
However, I do not know what the alpha carbon is in this case, and how I can show it.
Borek said:
What is alpha carbon in other cases?
You can have alpha carbon, for example, in glucose and maltose.
What makes this carbon 'alpha'? Why is it called this way? How does it differ from 'beta'?
I found the answer in Wikipedia.
Alpha keto-acid has keto group next to COOH, while beta keto-acid has keto group at the second Carbon from COOH.
The LHS molecule is alpha-keto acid, while RHS is beta-keto acid in the following picture.
http://dl.getdropbox.com/u/175564/alpha-beta-acids.png
Note that keto group in the RHS molecule is at the third carbon that is the second C from COOH.
Is everything correct?
If you were looking for the answer in wikipedia, it would be better to start at the very beginning:
http://en.wikipedia.org/wiki/Alpha_carbon
Other left.
Thank you!
So we have both alpha and beta carbons in both molecules
http://dl.getdropbox.com/u/175564/alpha-beta-carbons-updated.png
Is the carbons now correctly labeled with alpha and beta carbons?
OK now.
As you see concept of 'alpha'. 'beta' and 'gamma' carbons is widely used in chemistry. Not very formal, often very useful.
Borek said:
OK now.
I am unsure about alpha and beta carbons in http://www.laakis.com/wp-content/uploads/2008/12/picture-7.png" .
It seems that the same naming convention does not apply here.
Instead, the position of OH group seems to determine the name.
Yes. As I told you - it is not formal. Still, widely used. See GHB for example.
The alpha and beta conventions for sugars is completely different from the alpha, beta, gamma, etc. nomenclature that you were discussing previously.
For cyclic sugars, alpha refers to a cyclized sugar in which the OH group of the anomeric carbon (the carbon with two bonds to oxygen) is on the opposite side of the ring as the alkyl group on the ring.
Thank you both!
