physics user1
Difference between pulses, waves, and train waves
- Level: High School
- Thread starter physics user1
- Start date
- Tags
- Difference Train Waves
13 replies · 3K views · last reply
Discussion
Jon B
- 77
- 4
It is a damped sine-wave pulse that appears to have been gated. A sequence of them would be a pulse train. The wave is about shape.
- 786
In terms of daily life, waves are something which are waving and are not necessarily periodic, e.g. (real) water waves, sound waves, and EM waves. Mathematically, waves are the solutions of the wave equation.
Pulses are usually used to describe a propagating disturbance but localized in space at a given instant of time. A train of pulses (rather than a train of waves) are actually a superposition of many waves, therefore it also satisfies the wave equation, and with regard to the above paragraph it can also be called a wave.
Jon B
- 77
- 4
So non-sinousoidal tone pulses are okay like the distorted waveform in the picture. My favorite pulses are always made of a superposition of waves of various frequencies and amplitudes as a Fourier series.blue_leaf77 said:In terms of daily life, waves are something which are waving and are not necessarily periodic, e.g. (real) water waves, sound waves, and EM waves. Mathematically, waves are the solutions of the wave equation.
- 786
Yes, that's actually what I was talking about in the last sentence of my previous comment.Jon B said:My favorite pulses are always made of a superposition of waves of various frequencies and amplitudes as a Fourier series.
I don't know what you want to say there.Jon B said:So non-sinousoidal tone pulses are okay like the distorted waveform in the picture.
Jon B
- 77
- 4
I was thinking about a comment about sinusoidal wave shape not being a pulse.blue_leaf77 said:Yes, that's actually what I was talking about in the last sentence of my previous comment.
- 786
As I have suggested before, that the term "pulse" is most commonly used to describe a propagating disturbance which is localized in space in a given instant of time. This is what I believe as what most people, in particular scientists or engineers working in a field relevant to this term, have in their mind. So, a pulse does not seem to have been well-defined to refer to a certain distinct physical phenomena, but it's a more convenient term to use to distinguish it from the continuous type of waves.Jon B said:I was thinking about a comment about sinusoidal wave shape not being a pulse.
Following this, a continuous stationary sinusoidal function wouldn't normally be called a pulse.
Jon B
- 77
- 4
What is it when a continuous sinusoidal wave never crosses zero reference so that there is a train of pulses that doesn't produce upper harmonics like a square pulse does?blue_leaf77 said:As I have suggested before, that the term "pulse" is most commonly used to describe a propagating disturbance which is localized in space in a given instant of time. This is what I believe as what most people, in particular scientists or engineers working in a field relevant to this term, have in their mind. So, a pulse does not seem to have been well-defined to refer to a certain distinct physical phenomena, but it's a more convenient term to use to distinguish it from the continuous type of waves.
- 786
There is no sinusoidal wave which does not cross the zero reference.Jon B said:What is it when a continuous sinusoidal wave never crosses zero reference so that there is a train of pulses that doesn't produce upper harmonics like a square pulse does?
Jon B
- 77
- 4
Right. It is undulating dc that looks identical to a sine wave. Like a mass in motion on a spring. The anchor is the zero reference and the sinus motion is above zero. Electronic magic.
- 24,488
- 15,064
Of course, a true signal is never a pure plain wave. You can have very many "wave forms", like "wave packets" or "wave trains". An example for the letter is a sinusoidal wave, switched on at a finite time ##t=0##. We put the phase velocity of the wave ##c=1##. Then the right-moving wave train is given by
$$f(t,x)=\Theta(t) \sin[\omega_0 (t-x)].$$
It can be written as a Fourier integral
$$f(t,x)=\int_{\mathbb{R}} \mathrm{d} \omega \frac{1}{2 \pi} A(\omega) \exp[-\mathrm{i} \omega (t-x)].$$
We get the spectral function by the inverse Fourier transform
$$A(\omega)=\int_{\mathbb{R}} \mathrm{d} t f(t,0) \exp(\mathrm{i} \omega t) = \int_\mathbb{R} \mathrm{d} t \Theta(t) \sin(\omega_0 t) \exp(\mathrm{i} \omega t).$$
Decomposing the sine into exponentials gives
$$A(\omega)=\int_0^{\infty} \mathrm{d} t \frac{1}{2 \mathrm{i}} \{\exp[\mathrm{i}(\omega+\omega_0) t]-\exp[-\mathrm{i}(\omega+\omega_0) t] \}.$$
Now this integral is not well defined. So we regularize it by adding a damping factor to the integrand
$$A(\omega)=\int_0^{\infty} \mathrm{d} t \frac{1}{2 \mathrm{i}} \{\exp[\mathrm{i}(\omega+\omega_0) t]-\exp[\mathrm{i}(\omega-\omega_0) t] \} \exp(-\eta t), \quad \eta>0.$$
Then we get
$$A(\omega)=-\frac{\mathrm{i}}{2} \left [-\frac{1}{\mathrm{i}(\omega+\omega_0+\mathrm{i} \eta)}+\frac{1}{\mathrm{i}(\omega-\omega_0+\mathrm{i} \eta)} \right ]=\frac{\omega_0}{\omega_0^2-(\omega+\mathrm{i} 0^+)^2}.$$
As you see, that's a pretty broad spectrum around the frequency ##\omega_0##.
Then we get
Jon B
- 77
- 4
I was using the road for the reference instead of the axle.
- 786
Could you possibly be thinking about something like ##y(t) = \cos(\omega_0 t)+1##? It might look like a sinusoidal function but it's actually not. Try to calculate the Fourier series coefficients for ##-\pi/\omega_0 < x < \pi/\omega_0##, the coefficients for sine terms vanish but those for the cosine do not. In particular, the series will contain other harmonics as the sinusoid component ##\omega_0## due to the constant term ##1##.Jon B said:Right. It is undulating dc that looks identical to a sine wave. Like a mass in motion on a spring. The anchor is the zero reference and the sinus motion is above zero. Electronic magic.
Jon B
- 77
- 4
Sounds good to me.blue_leaf77 said:Could you possibly be thinking about something like ##y(t) = \cos(\omega_0 t)+1##? It might look like a sinusoidal function but it's actually not. Try to calculate the Fourier series coefficients for ##-\pi/\omega_0 < x < \pi/\omega_0##, the coefficients for sine terms vanish but those for the cosine do not. In particular, the series will contain other harmonics as the sinusoid component ##\omega_0## due to the constant term ##1##.
High School
Waves travelling between strings
- WheatNeat
- · Replies 3 ·
- Mechanics
- Replies
- 3
- physics user1
- · Replies 2 ·
- Mechanics
- Replies
- 2
- zinn
- · Replies 0 ·
- Astronomy, Astrophysics, Cosmology
- Replies
- 0
Undergrad
Phase difference between sound waves
- FAS1998
- · Replies 3 ·
- Mechanics
- Replies
- 3
- Dolinting
- · Replies 2 ·
- Mechanics
- Replies
- 2
- RubinLicht
- · Replies 14 ·
- Mechanics
- Replies
- 14
- Txema
- · Replies 6 ·
- Electromagnetism
- Replies
- 6
- Herbascious J
- · Replies 12 ·
- Special and General Relativity
- Replies
- 12
- Point Conception
- · Replies 10 ·
- Introductory Physics Homework Help
- Replies
- 10
- hello478
- · Replies 21 ·
- Replies
- 21
